-   -   intake air temp sensor (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/978653-intake-air-temp-sensor.html)
philip j 11-24-2017 03:54 PM
Looking for ideas... I want to change the location of the intake air temp. sensor on my EFI'd 3.4. I currently have it mounted on the intercooler close to the outlet/throttle body. Has anyone drilled/tapped their Carrera intake manifold and placed it after the throttle body? I do get a lot of heat soak where I have it installed now. Any ideas appreciated... TIA Philip
jpnovak 11-24-2017 06:35 PM
Yes, I have drilled and tapped a 3.2 manifold below the throttle in the center section on the passenger side. slight heat soak after sitting. Cools quickly after starting.
I don't think you will see any performance difference between a location below or above the throttle. Both are getting direct airflow, post intercooler.
philip j 11-24-2017 06:52 PM
Hey Jamie, that's what I was looking for... Have any pics of location? I was worried about obstruction/possible turbulence or air flow problems. Philip
turbobrat930 11-27-2017 12:00 PM
Just curious, Why is it heat soaking so bad? Have any pictures you could share? ( I know we have a lot of variations in I/C sizes, locations of exit points, etc) Is the sensor itself heat soaking, or the air coming past it?
Tippy 11-27-2017 12:12 PM
Philip, I have mine how you have yours and it's been the best so far. I'd think in the intake would be worse??
turbobrat930 11-27-2017 12:36 PM
I would also think that putting the Intake Air Sensor in the intake mani, would not only lend itself to more heat soak, but also, even though these engines are boosted, I would think that inside of the intake mani, the air would not be straight and free flowing, but turbulent ( I don't know how else to articulate it, not the best choice of words)
philip j 11-27-2017 01:03 PM
I see a lot of heat soak when I have shut my engine down for 5 minutes or so... read here somewhere that the sensor after the throttle body was best. I am pulling my engine this winter to go through some things, and engine temp/intake temp are on the list... Philip
http://forums.pelicanparts.com/uploa...1511784092.JPG
'76 911S 3.0 11-27-2017 01:05 PM
Are you using a closed element or open element temp sensor? Both will heat soak with an engine off and exposed to the radiant heat; however, an open element will return to normal temps far quicker than a closed element sensor will once the engine is running.
turbobrat930 11-27-2017 01:20 PM
Here is where I have mine located.... Just above the TB on the 90 deg elbow. I do not see hardly any heat sink, and the second picture, is of the sensor itself.... Hope this helps.
[IMG]https://farm3.staticflickr.com/2902/...55a418d0_h.jpg20140426_185415 by Brad, on Flickr[/IMG]
[IMG]https://farm7.staticflickr.com/6230/...9049597f_b.jpgIMG_0152 by Brad, on Flickr[/IMG]
philip j 11-27-2017 01:23 PM
using a GM open air for intake temps...
https://www.diyautotune.com/product/gm-open-element-iat-sensor-with-connector/
xbmwguy 11-27-2017 04:31 PM
I️ have mine located same as Brad with same results, minimal heat soak
dos531 11-27-2017 04:53 PM
How about one of these in that silicone elbow?
http://www.siliconeintakes.com/holset-turbocharger/-p-500.html
TurboKraft 11-27-2017 04:54 PM
We locate them in the intercooler's outlet, or the pipe between the intercooler and throttle body (not applicable to you, you have a silicone elbow). Never have an issue with heat soak.
Does your intercooler have cast tanks or sheetmetal? Even if it's a real Garretson-made one, he did both. The actual outlet section is sure to be sheetmetal, you could weld on a 3/8" NPT bung and move it there. The intake manifold is thicker cast aluminum, and probably the most likely to heat soak first.
dap930 11-28-2017 03:04 PM
Philip,
I am using the same Bosch IAT sensor as Brad, mounted in my Mustang throttle body. I still get some heat soak, but I changed my WUE from engine cycles to 0.1 seconds and increased my WUE time at high intake temperatures. I have 1.5 minutes of WUE at 220*F that tapers down in time at lower temperatures back to 0.0 minutes at 120*F which is where my engine is fully warmed up based on my CLT set up. Note that if you change WUE from engine cycles to 0.1 seconds, the y-axis still reads "engine cycles" instead of "seconds" in the WUE taper dialog box in TS.
philip j 11-28-2017 04:05 PM
Originally Posted by dap930 (Post 9829901)
Philip,
This sounds good Dennis, I should be able to leave my sensor where it is but manipulate the fuel settings to accommodate the heat soak. Looks like I'll have a big learning curve once I have the MS3pro is installed... Can't wait. ;-) Philip
philip j 11-28-2017 06:15 PM
Silicone Port System
That's a really cool fitting... LOL bet there's no heat soak there!
