intake air temp sensor
Looking for ideas... I want to change the location of the intake air temp. sensor on my EFI'd 3.4. I currently have it mounted on the intercooler close to the outlet/throttle body. Has anyone drilled/tapped their Carrera intake manifold and placed it after the throttle body? I do get a lot of heat soak where I have it installed now. Any ideas appreciated... TIA Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
I would rather be driving
Yes, I have drilled and tapped a 3.2 manifold below the throttle in the center section on the passenger side. slight heat soak after sitting. Cools quickly after starting.
I don't think you will see any performance difference between a location below or above the throttle. Both are getting direct airflow, post intercooler.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
E-85 sippin drunk
Just curious, Why is it heat soaking so bad? Have any pictures you could share? ( I know we have a lot of variations in I/C sizes, locations of exit points, etc) Is the sensor itself heat soaking, or the air coming past it?
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
Chain fence eating turbo
Philip, I have mine how you have yours and it's been the best so far. I'd think in the intake would be worse??
E-85 sippin drunk
I would also think that putting the Intake Air Sensor in the intake mani, would not only lend itself to more heat soak, but also, even though these engines are boosted, I would think that inside of the intake mani, the air would not be straight and free flowing, but turbulent ( I don't know how else to articulate it, not the best choice of words)
Are you using a closed element or open element temp sensor? Both will heat soak with an engine off and exposed to the radiant heat; however, an open element will return to normal temps far quicker than a closed element sensor will once the engine is running.
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 |
E-85 sippin drunk
Here is where I have mine located.... Just above the TB on the 90 deg elbow. I do not see hardly any heat sink, and the second picture, is of the sensor itself.... Hope this helps.
[IMG] 20140426_185415 by Brad, on Flickr[/IMG][IMG] IMG_0152 by Brad, on Flickr[/IMG]
using a GM open air for intake temps...
https://www.diyautotune.com/product/gm-open-element-iat-sensor-with-connector/
I️ have mine located same as Brad with same results, minimal heat soak
88 930 3.4 ,Twin plugged billet Xtreme cylinder heads and denso COPs, Dougherty custom GT 2 evo cams,pauter rods,Garrett Gt40,ms3x Efi ,1100cc injectors,extrude honed 3.2 intake,TK billet fullbay I/C,MODE headers,KEP stage 2, E-85, 706 rwhp |
How about one of these in that silicone elbow?
http://www.siliconeintakes.com/holset-turbocharger/-p-500.html
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC '12 Gallardo LP-570-4 Performante Ducati 748R |
We locate them in the intercooler's outlet, or the pipe between the intercooler and throttle body (not applicable to you, you have a silicone elbow). Never have an issue with heat soak.
Does your intercooler have cast tanks or sheetmetal? Even if it's a real Garretson-made one, he did both. The actual outlet section is sure to be sheetmetal, you could weld on a 3/8" NPT bung and move it there. The intake manifold is thicker cast aluminum, and probably the most likely to heat soak first.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Philip,
I am using the same Bosch IAT sensor as Brad, mounted in my Mustang throttle body. I still get some heat soak, but I changed my WUE from engine cycles to 0.1 seconds and increased my WUE time at high intake temperatures. I have 1.5 minutes of WUE at 220*F that tapers down in time at lower temperatures back to 0.0 minutes at 120*F which is where my engine is fully warmed up based on my CLT set up. Note that if you change WUE from engine cycles to 0.1 seconds, the y-axis still reads "engine cycles" instead of "seconds" in the WUE taper dialog box in TS.
-Dennis 1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R Last edited by dap930; 11-28-2017 at 03:26 PM.. Reason: accidental post before finished |
