-   -   3.4L Turbo system complete for sale (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/985783-3-4l-turbo-system-complete-sale.html)
m42racer 01-28-2018 03:50 PM
I am selling my used 930 3.4L EFI system complete. This system is capable of producing 650+ HP depending upon fuel type and manifold pressure used. Single Turbo set up with less than 2000 miles from new. PM for photos and further information. This will be an opportunity to achieve this level of performance at a lot lower cost. Will entertain any reasonable offer.
The system is complete, in great condition with some parts rebuilt, and will require fitting only to use.
The system includes the following parts.
98.0mm Piston and cylinder kit. 3.4L with stock crank. Cleaned, crack checked and measured.
Twin plug head set, fresh rebuilt, new guides and new seats, ready to use. Ported with flow numbers.
Camshaft set, polished and coated
Rocker arms, rebuilt, coated.
3.2L intake manifold complete with Injectors and fuel rails, all plumbing
Large Intercooler and mounts
Exhaust complete with dual wastegates and muffler
KKK Turbocharger with drain tank
Primary single headed distributor with internal sync sensor, top plugs
Secondary single headed distributor cam driven off left side camshaft, lower plugs
All ignition wires included.
Exhaust cam covers
Mapped EFI technology EFI system with all sensors., complete engine and chassis harnesses.
M&W CDI system
gsxrken 01-28-2018 03:55 PM
I have four children; will part out. PM me.
Tippy 01-28-2018 05:37 PM
The most confusing post I've ever seen here.
No brands, no photos, nothing.
dos531 01-28-2018 07:50 PM
https://i.imgur.com/a6gGDa4.jpg
m42racer 01-28-2018 08:45 PM
I did suggest to PM me for photos and further info.
But,
P&C's are Mahle
Heads are Porsche twin plug rebuilt by Performance Developments
Camshaft set is Performance Developments custom design
Rockers are Porsche, rebuilt by Performance Developments and hard chromed and ground back to original specs
Intake is Porsche 3.2L Carrera modified to fit 930 application
Intercooler is full width custom built by Jerry Woods
Exhaust is combination of SSI and custom with twin wastegates built by Jerry Woods
This engine was originally built by Jerry Woods , sold to my customer who swapped it out for an engine I had along with added $$$. It is currently at PD undergoing a full restoration back to stock and will be sold as soon as its completed. These parts are the take off parts from the original 3.4L turbo engine by JW. If you need more info, photos etc, PM me.
If you have original 930 Intake and Exhaust parts to exchange, I am interested and can work out some sort of deal.
Simon B.
Tippy 01-29-2018 06:19 AM
Simon, do you mind posting the head CFM #'s?
I don't need the heads, it was just for the sake of data. Curious what the flow rate after porting.
I'm thinking about porting my Carrera 3.2 heads, and wanted to see some numbers to compare to.
puddy 01-29-2018 10:26 AM
I didn't think a KKK turbo would work for that kind of power.
I'm curious what a package like this is worth, $10k ish?
xbmwguy 01-29-2018 04:03 PM
Thought the same. Didn’t know of a KKK capable of north of mid 5s max
Tippy 01-29-2018 05:26 PM
Originally Posted by xbmwguy (Post 9905342)
thought the same. Didn’t know of a kkk capable of north of mid 5s max
k29??
kevinbodman930 01-29-2018 06:36 PM
Simon,are you selling the efi off the motor or the entire motor or bothe?
m42racer 01-29-2018 07:32 PM
I'm having an engine rebuilt I swapped out a few years ago. It came as a Jerry Woods built 3.4L EFI 930 engine with less than 1500 miles. It has the Carrera manifold etc. somewhat typical EFI engine. I installed it and ran the engine for less than 500 miles. The last time the car (1989 930) was registered was 1999. I have stored it since.
I'm building it back to stock to sell, therefore all of the parts that were changed to make it an EFI engine are take off's and for sale.
I have had the shop rebuilding this engine for me, go through a lot of the parts to make sure they are perfect and have just asked them to go through everything, clean everything ready to assemble onto an engine.
The parts come complete and I will not separate. The kit is worth something as a whole and not broken up.
I will have the shop post some photos of the whole system ASAP.
Simon
kevinbodman930 01-29-2018 08:05 PM
I would like to know what it is before I commit.Can u pm the shops phone #.Thankyou
Carbster09 02-08-2018 01:46 PM
What are the cam specs? It would go in a healthy 3.3 w a K27 and full width intercooler.
m42racer 02-09-2018 01:58 PM
I have asked for the cams to be measured. Not sure what your other request is?
Can you repeat?
Edelweiss 02-12-2018 11:37 PM
3,4
Dear Sir,
we may have a customer for your package - please get in touch with us.
Thank you !
Dirk
kevinbodman930 02-13-2018 09:49 AM
Originally Posted by Edelweiss (Post 9924085)
Dear Sir,
Thank you !
Dirk
Kinky
