But thanks for looking out. You never know someone's mechanical level. If the slip joints become an issue I'll just tig them closed and have the headers recoated. But they fit together really tight. I'll be checking for evidence of leakage just like Rawknee does. |
In retrospect, I wish I had simply gone EFI. At the time I didn't want to modify things 'too much' and kept the CIS. This meant a fuel head mod, adjustable wur, two new fuel pumps, 009 injectors, and larger diameter euro fuel lines and lots of time. At first I was lean, now I am too rich. This is part of the reason that I've increased the wastegate springs to 1.1 (not 1.2, sorry for the mistake) and installed a RPM switch. I need to get it back on the dyno again to see how it does with more air. There is a limit to how much I could dial down the warm control pressure and still have a decent AFR at cruise. Finally, I am running a LSD and 8:41 ring and pinion. The short R&P makes 4th gear usable in the 930 gearbox again and really livens up the car - highly recommended. http://forums.pelicanparts.com/uploa...1523634863.png |
Tonger is the only guy I know whose CIS 930 has the problem of being *too rich* from peak torque to redline!
The lighting in this picture is deceiving the view of the inside of the collector. There may be risen edges from the back-purge welding process but there is no slag that could cause a problem of any sort. We have never had any reported instance of slag issue in any of our header systems. Quality in our welding process is one of the things that separates us form the other manufacturers, we take that very seriously.
http://forums.pelicanparts.com/uploa...1523641679.jpg |
Rather than welding slag, this actually looks like extra material from when the collector was sanded flush or cast. If you look closely at the picture, there is a thin grey line over the periphery that looks like casting flash or sanding flash. It's not a big deal, the section with the red arrow at 8 o'clock is just partially broken off. That's why I suggested that Derrick clean it up and take it the rest of the way off. Actually, I think that he must have seen it too when I pointed it out in his post. Quote:
http://forums.pelicanparts.com/uploa...1523645315.jpg |
A carbide bur on a die grinder or roto tool would clean those raised edges off smooth in 30 seconds or less.
Or do it by hand with a rat tail file if you can get at them. |
http://forums.pelicanparts.com/uploa...1523665431.jpg |
Welds look nice and tight.
Sent from my SM-N950U using Tapatalk |
Ditto! Those are nice. As a new to TIG welding welder that is hard to do. My welds are twice that width.
Originally Posted by Tonger ..."Equal length but longer and more tortuous vs. nonequal length but shorter with fewer curves"
My tuppence here... from Physics 101: Assuming both have the same I.D., the latter inherently offers lower pressure drop and less turbulence. Thus inherently the winner (though yes there are other important factors of optimum velocity to turbo inlet & gas pulsation delivery as previously noted by others). What is the net effect difference? Guess ~1% better acceleration, 1.5% higher peak? Dunno, only Tonger's dyno challenge will tell (unless of course someone has the software to model it), however I seriously doubt it's seat of the pants detectable either way. |
BTW - major kudos and thanks to Tonger for posting the dyno sheet! Much appreciated. |
| All times are GMT -8. The time now is 03:58 PM. |
