broken header pipe, is this common
I have this support shaft (I believe that is what it is) that connects the turbo waste-gate pipe to one of the exhaust pipes from the cylinder. Yesterday I heard my engine sounding like a 1940s pickup, and looked down and looks like the rod has broken from the header pipe and now I have an exhaust leak. Has anyone seen this and is it possible to weld up this without taking the whole exhaust off.
81 -930 82 - Austin Mini 998 78 Mini 1275cc -totaled 83SC Euro w/77 3.0 Carerra Eng.--sold Several other daily drivers not worth mentioning... |
Looks like a set of GHL headers... I have the same ones, good headers. You should take them off to do a proper job. Pretty hard to TIG up in there...
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Well, I drove it to this local muffler place, the guy took 5 mins and $20 and welded a nice bead all around. Sounds like my old 930 again (the tractor sound was embarrassing). So far so good...but still wondering if this is a stress point and it will happen again or not.
81 -930 82 - Austin Mini 998 78 Mini 1275cc -totaled 83SC Euro w/77 3.0 Carerra Eng.--sold Several other daily drivers not worth mentioning... Last edited by jwakil; 05-07-2018 at 07:18 AM.. |
It may. The stainless gets brittle over time and continues cracking at the edge of new weld.
If it cracks again it's time for new headers.
Derrick |
You'd have to remove it and clean it down to good stainless in order for the weld to not be contaminated and weakened.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
I had a set like that, and had them repaired a few times.
I got some RarelyL8 headers. problem solved. Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Another solution would be to change Wastegate, one tial46 "for example", it is much lighter than that of the origin and will thus be less binding for your collector of escape. ;-)
JW: I may have some Rarlyl8 headers for sale in a few months so pm if you decide you want an alternative. They will also come with new unused heater boxes.
The right way to fix it if you want it to last. Puts the stress from the WG hanger into the flange instead of the primary.
Metal Guru
Grade 304 austenitic stainless is not recommended for "hot service" (between the exhaust manifold and the catalyst). It is prone to corrosion cracking. It is the material that most aftermarket fabricators choose, unfortunately.
OE's use 409 (ferritic stainless) as it is not susceptible to corrosion cracking and the cost is relatively low. Grade 321 austenitic stainless is also good in hot service but is more expensive. It is used primarily in aircraft. Headers made from 321 stainless (like those sold by Brian) are worth the investment. I have a header that Ben from M&K made for me 10 years ago. It's fabricated from 321, has not cracked and probably never will.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
Why cheap out on 321, go with Inconel 625.
