empire0007's Avatar
Parting out a hot rod lots of $$$$$$$$$$
• Interior: 993 Black Alicante with red stitching for sale,
2 door panels, brake, shift boot and center counsel
Looking for offers
Mike Hakimi
Empire Pacific Investigative Services
www.epis.us
epg@usa.com
Old 03-11-2019, 09:11 PM
empire0007's Avatar
3.5" Exhaust System
For Sale
Make me an offer
Mike Hakimi
www.epis.us
epg@usa.com
Old 03-11-2019, 09:15 PM
empire0007's Avatar
Parting out this super expensive Hot Rod, due to an accident
I have a 3.8L TT engine for sale, which was fully built (top & Bottom), with all high end parts, No Expense Spared. The engine was built by 911-Design, as we all know Lauren and his reputation worldwide.
ENGINE: is a 964 NS case, Potter Rods, big oil cooler, 3.8L Porsche Motorsports piston & Cylinders, GT2 EVO Cams, 993 welded heads, with all the high goodies, High Performance vale springs, High performance Titanium Retainers and spring seats, etc., Billet Aluminum Valve Covers, Huge injector’s for E85 fuel setup. All the machine work was done by Aasco Motorsports. (Just the repair receipt from 911-Design was around high $40,000 + $10,000 parts for this engine only and around $12000 for Aasco, machining 3.8L, heads, etc.) That’s $62000 Dollars plus the engine.
TURBOS & INTERCOLLER: The two turbos are Custom Garrett GT28 housing with GT3071 Compressors (hand built). Custom Big Full Intercooler with two electronic control fans, Tial Wastegates, Custom headers & Exhaust system, Custom heat shield for the turbos and headers. This costed me over $17,000
ELECTRONICS/COMPUTER SYSTEM: is Haltec with lots of options, including Flex Fuel option. Custom Race Harness, gold pins., Hold down tab for ignition spark plug wire connector. This costed me $8000.00
TRANSMITION: is a G50 with limited slip which is like new with brand new Stage 2 Clutch and light Flywheel. $11000
THIS ENTIRE COMPLETE SETUP IS FOR SALE FOR $50K. This will cost you over 90K to set this up.
I have dyno sheet, dyno video, full receipt, pictures, etc.
Reason I am selling this, I got into an accident 2 weeks after the car was fully set. My wife will divorce me, if I was going to transfer this into a new car. My loss your gain.
Make me an offer, everything on this car is for sale
SUSPENSTION:
THE COMPLETE SUSPENSION WAS SET BY MIRAGE INTERNATIONAL
ERP 935 Front Suspension kit $1850
Offset Camber Plates $630
935 Rear Spring Plate Kit $849
Turbo Tie Rod Kits $235
Bolt on Adjustable Bump Steer Kit $335
Complete RSR Valve Racing Struts $747
Rear Shock Tower Reinforcement $?
Coilover Springs $2500
Spherical Control Arm Bearings$?
Monoball Bearing Cartridges $260
Trailing Arm Reconditioning Service $400
Adjustable Front & Rear Sway bars$700
Spherical Control Arm Bushing and Bearing $480
A 9K value for only $4300.00 Dollars.
OTHER PARTS
Battery Relocation Kit $175
Battery Mount Kit Odyssey $145
Battery Disconnect Switch $45
Odyssey Battery $180
Rear Tie down $40
Rennline Aluminum Floorboard $140
Rennline Aluminum Gas Pedal Adjustable kit 4 pieces $350
RSR Style Engine Mount Cross Bar & Solid Aluminum Motor Mount $325
Momo Steering wheel $260
2 GT3 Style Carbon fiber Seats & Seat Brackets $3000
2 set 5-point Harness seatbelts $300
Brakes:
These are from a Porsche 996 turbo in excellent shape front and rear Calipers and Rotors $1500.00
Brake Master Cylinder 911/930 turbo kit Sport 23MM & Brake Fluid Reservoir – G50 Transmission $250
Tilton Brake Pedal Bias Adjuster Kit $100
Convertible 993 top
Exhaust System
METHANOL SYSTEM
I have an Alky Alcohol Injection System with 5 gallon tank installed in front $700
SEATS:
Real Carbon Fiber GT3 Style Seats with black leather and swade and red stiching and Porsche embroidery on the seats, including the mounts. $2400
GAUGES:
Porsche 911 Gauges 5 pieces with red LED lights $2700
Porsche 964 Rear Lights:
These real lights are in perfect condition. Center, Left & Right $700
DOORS:
Porsche 911 SC Driver & Passenger Doors with Sound Proofing $500.00
FUEL TANK
OEM Porsche 1978 911SC fuel tank, which was recently professionaly done. $350.00
WHELLS:
These are CCW 3 Piece LM5 Wheels, that are 18x12 & 18x10 with Toyo R888 racing tires. Front driver and rear passenger are damaged. It’s repairable, since they are 3 piece wheels. Center is mat black and outside is glossy black asking $750.00
Porsche 911 964 993 Sound Pad swade with Porsche RS 3.8 red stiching $100
Other Parts:
Master Disconnect Switch Battery $25
Electronic Oil Pump- electrical fluid transfer unit - $150
LED Aircraft intercooler Temp Gauge. Digital inercooler differential indicator gauge. Indicateds inlet, outlet and split temps in Fahrenheit $200
Mike Hakimi
www.epis.us
epg@usa.com
Old 03-12-2019, 05:31 PM
empire0007's Avatar
Mike Hakimi
www.epis.us
epg@usa.com
Old 03-12-2019, 05:34 PM
empire0007's Avatar
Mike Hakimi
www.epis.us
epg@usa.com
Old 03-12-2019, 05:35 PM
empire0007's Avatar
Mike Hakimi
www.epis.us
epg@usa.com
Old 03-12-2019, 05:39 PM
Are the ARP Studs for sale?
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 03-13-2019, 12:03 PM
T77911S's Avatar
interested in heads and cams
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-14-2019, 05:21 AM
empire0007's Avatar
Hello there, no the ARP are installed in the engine
Mike Hakimi
www.epis.us
epg@usa.com
Old 03-14-2019, 07:24 AM
empire0007's Avatar
Hello everyone. All the engine parts are what is inside this motor and I am selling this motor as fully complete with the electronics, plug and race. Or I can take the turbos and intercoller out sale it but not taking the engine apart.
The engine was built by 911-Design and it would be a shame to take it apart. Engine has around 1500 total miles, before I got into an accident.
Mike Hakimi
www.epis.us
epg@usa.com
Old 03-14-2019, 07:27 AM
M5guy's Avatar
Why isn’t the car repairable? I saw a GT3 get a whole new front clip from the windshield forward.
Old 03-14-2019, 11:27 AM
Man, sorry to hear about your car. I can't imagine how you must be feeling.
Seems you have PMs disabled, so posting on the thread.
If this is a dual brake master cylinder setup (for use with G50), I'll take it if it fits inside the cabin without cutting holes in the firewall (e.g. if the masters are angled up).
Which depends on what brand/model it is. Any pictures?
G50/50, I presume? Good price. Pity I can't squeeze that into my tub.. Almost tempted to buy it for the internals...
Very interested in this, too. Any pics?
And trying hard to skip quickly over the list of suspension pieces every time i scroll...
'77 S with '78 930 power and a few other things.
Old 03-14-2019, 07:10 PM
empire0007's Avatar
I don't want to spend that kind of money on a salvage title
Mike Hakimi
www.epis.us
epg@usa.com
Old 03-14-2019, 07:28 PM
Just sent you an email re some of the stuff you have listed FS.
Anthony @ Voitureltd Bayside WI.
Old 03-15-2019, 11:36 AM
Hey Mike,
For my 1996 Porsche 993 TT, Im very interested in buying the Carbon Fiber GT3 Style Seats u listed for Sale?
Questions:
•*Are they still available?
•*Is $2400 your best offer; or are you willing to go lower?
•*What condition are they in?
•*Can you send me images?
Please call to discuss. Below is my email address and cell#
Kevin
Kevin.Ford@millercoors.com
414.350.3563
911 SEATS:
Real Carbon Fiber GT3 Style Seats with black leather and suede and red stitching and Porsche embroidery on the seats, including the mounts. $2400
Old 03-15-2019, 11:44 AM
TurboKraft's Avatar
Mike,
Really sorry to hear about this. :-\
I hope someone steps forward and buys the whole thing, transfers it to another chassis.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 03-15-2019, 04:56 PM
Depending on the condition of Seats I will ill offer $1800-2000 or OBO.
Originally Posted by Kfordieoz View Post
Hey Mike,
Questions:
Kevin
414.350.3563
911 SEATS:
Old 03-15-2019, 06:18 PM
Are u still selling the seats? What is your offer.
Old 03-16-2019, 09:36 AM
Not factory seats?
Which manufacture please?
PCA, POC & SCCA long time Member
Old 03-16-2019, 09:42 AM
call me im interested in engine trans and pedal assy .
Old 03-18-2019, 07:24 PM
