scratched case half. How bad?
Hi everyone,
Rebuilding my 1989 911 3.2 with 212K miles on it and no top end or case work ever. Yesterday, removed case half set aside, and was done for the day. left the oil pump in for today. I don't have any 911 engine rebuilding experience, except that I replaced my timing chains (successfully) about 4 years ago.
Problem statement: When I was bending one of the tabs on the nuts for the oil pump, my screwdriver slipped, and scratched the case half. I'm nut sure how deep, but I'd have to think it's a couple thousandths of an inch?
The start of the scratch is pretty close to the grunge line, which I assume is the edge of the inside of the case?
Would appreciate some advice on whether this is a small, medium or large problem. For what it's worth, it seems like there are other scratches, very straight, and parallel to the case half edge, but not by me.
Pic Below.
Thanks in advance for any thoughts or advice,
Mark
1989 911 Carrera 3.2
2009 Audi A4 2.0TQA
2017 BMW X3
2007 BMW 328xi
1971 BMW R60/5
Old 07-15-2018, 04:29 PM
Chain fence eating turbo
Scrap the cases, they’re unsalvageable.
Just kidding, just make sure you get the area nicely covered with Threebond or Loctite 574 during reassembly.
Old 07-15-2018, 05:32 PM
304065's Avatar
That will cause a leak. Sand it down.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 07-15-2018, 06:57 PM
Yamabond, threebond, is the answer but follow the directions and apply to both R and L flanges as instructions dictate.
Bruce
Old 07-16-2018, 04:16 AM
So to fix this, sanding down making a deeper depression will prevent the leak?
I don't follow this logic?
I just used Threebond and am super impressed with it. It'll fill that minor void no problem, unless I am not seeing the scratch posted?
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 07-16-2018, 05:55 AM
The scratch is the one directly left of the stud that ends up in the lhole. Again, was from a screwdriver that slipped when bending back one of the tabs on the oil pump nut. The stud in the picture is the actual pump stud. I can try to figure out by looking at the case halves whether this is a location where oil could get from "inside" to "outside".
Thx
2009 Audi A4 2.0TQA
2017 BMW X3
2007 BMW 328xi
1971 BMW R60/5
Old 07-17-2018, 04:20 AM
Functionista
manbridge 74's Avatar
I would block sand if any raised metal areas. Clean well. Then use a credit card or the like to fill gouge with JB weld. Re-block sand after 12 hours and carry on.....
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 07-17-2018, 05:17 AM
You sand the scratch to make sure you are knocking down any raised areas that were created by the screwdriver, not to expand any low areas. The screwdriver will make a microscopic trench that will have high points that are higher than the old case mating surface.
Old 07-17-2018, 09:03 AM
I don’t have the calculations in front of me, but the clamping force of the perimeter bolts and through bolts would easily push the high metal down IMO.
Old 07-17-2018, 09:55 AM
proporsche's Avatar
as Tippy said ..do not worry too much clean the area, apply 574 in my case i only would put it on one half of the case .The reason is if you do not know how much to apply it is possible you would use too much and that would not be goood;-)
Here is how i do it...
https://www.youtube.com/watch?v=IandhtwG5no
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 07-17-2018, 10:30 AM
shoooo32's Avatar
My case was pretty hacked from a previous owner's rebuild. I used an Arkansas stone to smooth it out and sealed the outer half with Yamabond (loctite 574 for the bearing saddle surfaces). Motor has 1500 miles and is leak free.
MSC sells the stones- coarse on one side/ fine on the other
https://www.mscdirect.com/browse/tnpla/00580381?cid=ppc-google-New+-+Abrasives+-+PLA_sNxHmM8jb___164110813434_c_S&mkwid=sNxHmM8jb|dc&pcrid=164110813434&rd=k&product_id=00580381&gclid=EAIaIQobChMInt3a5Nam3AIVFLjACh3k4AM4EAQYASAB EgJBxvD_BwE
-Tony
Instagram: @Pablo_the_Porsche | @RuchlosRallye
AchtungKraft #002
Old 07-17-2018, 10:44 AM
deburring and smoothing the case halves is called good engine building practice
Old 07-17-2018, 12:58 PM
I went over my case halfs with a piece of flat fine sharpening stone wetted with 3in1 oil. Iy nicely deburrs and leaves the surface silky smooth. This is what you want to do to the area with the scratch. The loctite sealant fills in all but the deepest scratches.
___oOo___
1972 S 911 Targa kit
http://forums.pelicanparts.com/porsche-911-technical-forum/863768-thats-my-first-911-restoration-thread-72-911-s-back-grave-maybe.html
Old 07-17-2018, 01:56 PM
That scratch looks pretty shallow.. I wouldn't worry much.. when you go to clean everything and scrape gently with a blade, (holding it perpendicular to the surface), clean it all, and then use the three bond.. it will all be fine.
Old 07-21-2018, 03:28 PM
