Piston Question
I'm in the midst of a rebuild, and can't locate replacement piston circlips (the ones that hold the piston pin in place). Will generic hardware-store steel circlips do the job, or is there a specialized part that I need to track down? Haven't been able to locate the latter in the pelican or performance products catalogs...
Any advice would be much appreciated... Thanks! --Pete |
Step away from the Performance Products catalog. Just set it down and no one will get hurt or pay too much. :D
Try the Porsche dealer or Engine Builder's Supply if Pelican doesn't have them. -Chris |
The circlips are available. DO NOT USE hardware store clips. They are a total unknown and you would be better off re using the old ones, however don't do this either. I think I got the clips thru IMC. Any local porsche engine builder or parts supplier should be able to obtain them for you. Stoddard also comes to mind. You might also try a machine shop like Ollies in Santa Ana, CA.
Got it, I will do as instructed. Thanks guys for the help!
--Pete |
| All times are GMT -8. The time now is 01:03 PM. |
