-   -   ignition timing for group b cams (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1003845-ignition-timing-group-b-cams.html)
john schlemmer 08-01-2018 10:07 AM
Hi, have been slowly working on an 1977 3.0 930 engine. I came across some used group b cams ground by web cams in nice shape and installed them. Anybody out there know the ignition timing specs for these cams? Thanks john
Flat6pac 08-01-2018 01:36 PM
Call web cam and the secretary will send you a spec sheet.
Bruce
Jeff Alton 08-02-2018 09:23 PM
Ignition timing or cam timing?
john schlemmer 08-03-2018 09:12 PM
Ignition timing, will try web cams. I have the duration intake is 233degress exhaust is 220 degrees.
BURN-BROS 08-04-2018 09:22 AM
Ignition timing is a function of compression ratio(cylinder pressure), combustion chamber size, peak torque RPM and mixture...
Web-Cam will not be able to help...they can only provide cam timing specs...Are you sure you don't mean " What intake lift dimension at TDC overlap does this cam require" ?
