ignition timing for group b cams
Hi, have been slowly working on an 1977 3.0 930 engine. I came across some used group b cams ground by web cams in nice shape and installed them. Anybody out there know the ignition timing specs for these cams? Thanks john
Old 08-01-2018, 09:07 AM
Call web cam and the secretary will send you a spec sheet.
Bruce
Old 08-01-2018, 12:36 PM
Jeff Alton's Avatar
Ignition timing or cam timing?
www.turn3autosport.com
Old 08-02-2018, 08:23 PM
Ignition timing, will try web cams. I have the duration intake is 233degress exhaust is 220 degrees.
Old 08-03-2018, 08:12 PM
BURN-BROS's Avatar
Ignition timing is a function of compression ratio(cylinder pressure), combustion chamber size, peak torque RPM and mixture...
Web-Cam will not be able to help...they can only provide cam timing specs...Are you sure you don't mean " What intake lift dimension at TDC overlap does this cam require" ?
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 08-04-2018, 08:22 AM
