3.2 to a 3.4 10.5:1 v 12.5 :1 what increase?
Hi Engine gurus,
I have a twin plugged 3.4 with 10.5:1 compression, GE 60 cams, 46 PMO What increase HP & toque could i expect if i install 12.5:1 Pistons? Any one have built such a engine and have dyno numbers? I can run up to 112 fuel. Thanks |
What are you getting now? Will depend on timing also. 12.5:1 is pretty high, even on 112 gas...
How about you run a set of PMO 50's instead?
Why PMO 50mm?
| All times are GMT -8. The time now is 01:43 AM. |
