Smile 3.2 to a 3.4 10.5:1 v 12.5 :1 what increase?
Hi Engine gurus,
I have a twin plugged 3.4 with 10.5:1 compression, GE 60 cams, 46 PMO
What increase HP & toque could i expect if i install 12.5:1 Pistons?
Any one have built such a engine and have dyno numbers?
I can run up to 112 fuel.
Old 08-09-2018, 02:47 AM
What are you getting now? Will depend on timing also. 12.5:1 is pretty high, even on 112 gas...
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 08-09-2018, 04:45 AM
BURN-BROS's Avatar
How about you run a set of PMO 50's instead?
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 08-09-2018, 06:54 AM
BURN-BROS's Avatar
Burnham Performance
Old 08-09-2018, 07:18 AM
Why PMO 50mm?
Old 10-14-2019, 03:53 AM
