JB Racing dizzy and CDI
Has anyone used the JP Racing twin spark distributor with two 3-pin CDI boxes?
I assume I can connect 12V to + wire, orange, and split the dizzy out, purple, to the points inputs, C, on the CDI units. Comments? |
It depends on the pickup type. As you appear to only have two wires from the distributor, my guess would be it has a VR (variable reluctor) pickup.
Unfortunately this is not compatible with a 3 pin CDI box. You either need to use 6 pin CDI units or change the pickup type to one that is compatible with a points type signal. Firstly, ask JB to confirm the pickup type. |
Johnny, thank you for your input.
From the JB documentation: The distributor has two internal magnetic pickups |
With magnetic pickups you will need to go to 2 Bosch 6 pin CDI’s or a pair of MSD CDI’s.
MSD Streetfires are the least expensive route. |
| All times are GMT -8. The time now is 06:46 AM. |
