3.0 to 3.2 SS upgrade
Other than buying new parts costing me big bucks are these options viable?
1) buy new Mahle jugs & pistons for approximately 5-6,000 2) buy used 3.2 mahle pistons and have my existing 3.0 jugs bored over size & electroplated 3) buy used 3.2 jugs and get them electroplated. Will I have to re-machine my 3.0L block to accept the 3.2 jugs Thanks David |
Looking for more power? That was fast. ;) I'm in the same contemplation boat.
The 3.0 cylinders won’t bore to 98 because of the sealing ring becomes too close to the bore.
3.2 cylinders can open to 98mm. You don’t need to cut case as cylinders are the same spigot Alternate idea 3.2 crank and rods and a good set of Mahle Carrera Ps will slide into your cylinders Three L crank and rods have excellent value to defray crank costs. Bruce |
I thought the benefit of a 3.2ss was the 3.0 stroke with the larger bore giving it a rev happy nature. I may be wrong, i'm mostly an idiot.
Just different ways to get cubes......
Bruce |
hmmmm, no replacement for displacement. Wonder what the cost difference would be, would be cool to see a kind of chart from a 3.0 rebuild to a 3.2SS build to a 3.4 build
Yea that would be awesome
or 3.5 :)
Call EBS Racing. I bought the 3.0 plated cylinders and JE pistons. Should have bought the 98mm bored out cylinders.
I totally agree with last posts = if u r increasing displacement for what ever reason, why not maximize your value on the new parts going to b using...
“ there is NO replacement for displacement “........... |
Coughturbocough!!
On a 79 SC - I found a good used set of Max Moritz P&C, 98mm 9.3 compression (going up from 8.5), then added 964 cam grind, aluminum flywheel, SSIs and M&K 2 in 2 our exhaust, still have CIS and I assume I went from 180Hp to a little over 200hp, but the torque is unbelievable. Built it up in 2010 and have been autocrossing it ever since. I love the car.
If I couldn't get the Max Moritz I had planned on getting a set of 84-89 Carrera Jugs and sending them to EBS for enlarging and plating and matching to J&E pistons. |
i went 98mm replated carrerra cylinders from ebs and cp pistons, twin spark EDIS and SSIs/Dansk Sport I am happy with the performance. Still not 'fast', but sufficiently better than stock that I finally stopped having negative thoughts. I chose to stay w/stock cams which I am happy with for road use. I wish I had gone with 9.5CR instead of 10.5 because of the increasingly limited supply of premium gas here. Now I need to carry octane booster on trips. But apart from that I am happy with the compromises I made. Swapping crank and rods, ARP bolts needed. Will the CIS handle that ? Big port heads or not ? What kind of exhaust to use with 3.4 ? Much larger scope than 3.2SS
I find myself spending a lot of time reading and learning about adding a turbo.... just so much gain for the money.
I built my 3.0 into a 3.3SS using 100mm Mahle pistons and LN Engineering "slip fit" 100mm cylinders. Added 964 cams, Carrera big port heads with twin plug crank fire ignition and an early large port CIS air box. Pistons are about 10.8:1 compression. I think I paid $4k for the cylinders, about $1.2k for the pistons, $1.3k for the Electromotive ignition and a couple hundred for a set of clean 964 cams. One big advantage to building a 3.0 engine is having the stronger rods and rod bolts compared to the 3.2 engine. I think my engine is making about 250 hp, maybe a bit more. Pulls strong up to 7500 rpms where I have the ignition cutout set. Total cost to do the engine was in the $10-$12K range.
Very well proven and desirable build Fred...
Fred any news on dyno
Dyno............
Where............
Any ideas what a set of 3.2L (95mm) cylinders go for? It looks like it will be just $1400 to get them bored out to 98mm and replated.
Thanks David |
Cost of cylinders...........
Actually, $1400 isn't too bad. A new set of cylinders will likely cost in the $3K to $4K range! I used the 100mm KN Engineering "slip fit" cylinders that were right at $4K! This is a case of "you get what you pay for"!
Broken Head Studs
I just bought an SC that has broken head studs I believe. It's from an 83 and has engine number 64D2571. I have pictures from the seller that show it underwent a rebuild several years ago but no documentation what was actually done. My ultimate goal for the car does not involve this engine so I'm trying to evaluate selling as a core vs. rebuilding and selling it. Can you give me any guidance? Thanks!
Just a thought on "There is no replacement for dispalcement".
Your car/engine is about 40 years old. If you want super fast - sell what you have and buy a newer car. Bigger and faster is not always better. These cars have tremendous character. They are old. That said, being old is part of their charm. Have you ever seen a track prepared early 911 or Alfa Romeo GTV? Would you really care about their displacent? |
| All times are GMT -8. The time now is 06:46 PM. |
