Harpo's Avatar
3.0 to 3.2 SS upgrade
Other than buying new parts costing me big bucks are these options viable?
1) buy new Mahle jugs & pistons for approximately 5-6,000
2) buy used 3.2 mahle pistons and have my existing 3.0 jugs bored over size & electroplated
3) buy used 3.2 jugs and get them electroplated. Will I have to re-machine my 3.0L block to accept the 3.2 jugs
Old 09-16-2018, 09:50 AM
Looking for more power? That was fast. I'm in the same contemplation boat.
Old 09-16-2018, 10:07 AM
The 3.0 cylinders won’t bore to 98 because of the sealing ring becomes too close to the bore.
3.2 cylinders can open to 98mm. You don’t need to cut case as cylinders are the same spigot
Alternate idea
3.2 crank and rods and a good set of Mahle Carrera Ps will slide into your cylinders
Three L crank and rods have excellent value to defray crank costs.
Bruce
Old 09-16-2018, 03:29 PM
I thought the benefit of a 3.2ss was the 3.0 stroke with the larger bore giving it a rev happy nature. I may be wrong, i'm mostly an idiot.
Old 09-16-2018, 05:28 PM
Just different ways to get cubes......
Bruce
Old 09-16-2018, 06:46 PM
Nux Nux is offline
Nux's Avatar
Alternate idea
Bruce
you could do both and get a 3.4ss....slippery slope
Old 09-17-2018, 05:00 AM
hmmmm, no replacement for displacement. Wonder what the cost difference would be, would be cool to see a kind of chart from a 3.0 rebuild to a 3.2SS build to a 3.4 build
Old 09-17-2018, 08:35 AM
Harpo's Avatar
Yea that would be awesome
Old 09-17-2018, 09:30 AM
Send a message via AIM to blockhed
or 3.5
Old 09-20-2018, 05:15 PM
VFR750's Avatar
Call EBS Racing. I bought the 3.0 plated cylinders and JE pistons. Should have bought the 98mm bored out cylinders.
Old 09-20-2018, 06:19 PM
911 tweaks's Avatar
I totally agree with last posts = if u r increasing displacement for what ever reason, why not maximize your value on the new parts going to b using...
“ there is NO replacement for displacement “...........
I live for 911 tweaks...
Old 09-21-2018, 12:49 AM
Coughturbocough!!
Old 09-21-2018, 07:12 AM
On a 79 SC - I found a good used set of Max Moritz P&C, 98mm 9.3 compression (going up from 8.5), then added 964 cam grind, aluminum flywheel, SSIs and M&K 2 in 2 our exhaust, still have CIS and I assume I went from 180Hp to a little over 200hp, but the torque is unbelievable. Built it up in 2010 and have been autocrossing it ever since. I love the car.
If I couldn't get the Max Moritz I had planned on getting a set of 84-89 Carrera Jugs and sending them to EBS for enlarging and plating and matching to J&E pistons.
Old 09-21-2018, 11:57 AM
i went 98mm replated carrerra cylinders from ebs and cp pistons, twin spark EDIS and SSIs/Dansk Sport I am happy with the performance. Still not 'fast', but sufficiently better than stock that I finally stopped having negative thoughts. I chose to stay w/stock cams which I am happy with for road use. I wish I had gone with 9.5CR instead of 10.5 because of the increasingly limited supply of premium gas here. Now I need to carry octane booster on trips. But apart from that I am happy with the compromises I made. Swapping crank and rods, ARP bolts needed. Will the CIS handle that ? Big port heads or not ? What kind of exhaust to use with 3.4 ? Much larger scope than 3.2SS
80SC (ex California)
Old 09-21-2018, 12:05 PM
I find myself spending a lot of time reading and learning about adding a turbo.... just so much gain for the money.
Old 09-22-2018, 11:09 AM
fred cook's Avatar
I built my 3.0 into a 3.3SS using 100mm Mahle pistons and LN Engineering "slip fit" 100mm cylinders. Added 964 cams, Carrera big port heads with twin plug crank fire ignition and an early large port CIS air box. Pistons are about 10.8:1 compression. I think I paid $4k for the cylinders, about $1.2k for the pistons, $1.3k for the Electromotive ignition and a couple hundred for a set of clean 964 cams. One big advantage to building a 3.0 engine is having the stronger rods and rod bolts compared to the 3.2 engine. I think my engine is making about 250 hp, maybe a bit more. Pulls strong up to 7500 rpms where I have the ignition cutout set. Total cost to do the engine was in the $10-$12K range.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 09-27-2018, 06:15 PM
911 tweaks's Avatar
Very well proven and desirable build Fred...
Old 09-28-2018, 03:36 AM
Fred any news on dyno
Old 09-29-2018, 05:52 PM
plexiform's Avatar
Where did you get this done for $12k?
1975 911s Restomod, 2005 MV Agusta F4 AGO, 2002 Moto Guzzi V11 Scura, 1983 BMW R100RT, 1978 R100S, 1989 R100RS, 1991 R100 classic (x2), 2023 Ford F150 Lightning
SOLD: 93 R100R, 03 R1150GSA, 85 R100S Mono, 03 996 turbo, 16 Norton 961 Commando, 03 R1100s BCR, 77 R100s, 09 S63 AMG, 74 911, 88 R100RS, 78 930, 01 996 C4, 05 Cayenne, 09 Audi TT, 03 Moto Guzzi V11 LeMans, 07 WRX STI, 03 R1150GSA, 78 R100/7, 01 Audi S4, 98 Audi A4, 98 R1200c, 78 GL1000, 92 Accord, 89 KE100
Old 09-29-2018, 06:22 PM
fred cook's Avatar
Dyno............
I live in a small town in S. Georgia. The only dyno here has a steep ramp leading up that my car won't manage. I've heard of others within a hundred miles or so but haven't checked them out.
FEC3
Old 09-29-2018, 07:19 PM
