andrew15's Avatar
Value or Uses of a 1R / 2R Case
For some reason I seem to have acculated a few 1R / 2R engine cases. As these are the first iteration of the magnesium cases found on the 2.0L engines and generally regarded as too weak to do much with, what are my options? Standard rebuild, performance rebuild w/ modifications, boat anchor?
Thanks for any advice!
Regards,
Andrew M
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 03-07-2003, 04:40 PM
Author of "101 Projects"
Wayne 962's Avatar
Essentially worthless. I believe that these are the 1969 cases? They didn't have separate bearing supports for the intermediate shafts, and thus wore out quickly. Expensive machining is required to get these back to spec, and the intermediate shafts must be matched to these cases (1969 only).
-Wayne
Old 03-09-2003, 01:13 PM
