-   -   2.2 T using E cams (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1011478-2-2-t-using-e-cams.html)
den912 10-27-2018 01:58 PM
2.2 T using E cams
I’m having my engine rebuilt and the guy doing it has suggested E cams and PMO carbs ,is this a good way to go and what’s the advantage of building it this was as oppose to stock
Thanks B
Trackrash 10-27-2018 06:59 PM
Lots of choices with these motors. I thought my stock 2,2 T motor was a sweet running motor.
Yea the E cams will bump up the horse power some. Perhaps +10. I imagine if that is the only mod made the Zeniths would be fine if opened up a few mm. PMOs probably would be an over kill if the cam is the only mod.
Since you are in there E pistons would be a nice addition, as would be larger cylinders. Then top it off with some head work and you would have a screamer.
Don't over look K&N air cleaners and a sport muffler. It all adds up.
cmcfaul 10-29-2018 10:31 AM
E cams will make a noticable difference. If you can increase the compression...another step in the right direction. 2.2 is a short stroke. Anything to lighten the valve train will help it rev.
Chris
73 E
Tyson Schmidt 11-09-2018 09:50 PM
You’ll need E or S pistons for the valve clearance. Also need the extra compression ratio with the more aggressive cam timing to get a decent dynamic compression ratio.
There are larger ventures available for the Zeniths. 30mm or 32 would be good along with jetting changes. Open the Intake ports up if they are smaller than 32mm.
sebastianroher 11-09-2018 10:39 PM
You could do what I'm doing 2.2S crank, 2.2S p's & c's with DRC mod-solex cams and S cylinder heads. Should be a fun little motor.
