Science is NOT optional
rbogh901's Avatar
Air cooled engine failure modes
Where are the most likely causes and results? Seems like catastrophic failures are less common than with the newer motors.
PCA member since 1993
Old 11-03-2018, 10:47 AM
Well I guess if you get a coolant leak in the air cooled cars it is not nearly as serious as in the water cooled ones.
Old 11-03-2018, 10:53 AM
Some of the ones I have seen were due to improper down shifts. Results were see though crankcases
Old 11-03-2018, 05:38 PM
rbogh901's Avatar
Ha ha. 14,000 rpm is bad?
Under normal use what are the most common catastrophic failures? It doesn't seem like there are many. Sure there are broken studs but even those motors soldier on and bring the car home. And the only water pump is for the windshield so a failure doesn't leave you on the side of the road.
Old 11-04-2018, 10:40 AM
Walt Fricke's Avatar
On an older motor, if you are really careless about checking the oil level, you could start starving the bearings of oil on hard cornering. The engine can't withstand whole lot of that. But one of the shop guys would be best placed for listing customer blunders.
Old 11-17-2018, 05:21 PM
