After the next project
x98boardwell's Avatar
3.2 TDC Motronic Rotor location for dist.
I am putting back together the 87' 3.2. There isn't a slot in the distributor to adjust the timing as Motronic does that all for me in my 87'.
When installing the distributor at TDC I can either get the rotor to just before the line as shown below or just after. Since it is turning clockwise on this motor I'm guessing this is the proper placement.
Can someone confirm I'm correct or is there something I'm missing?
Thank you!
Current cars: 2012 Cayenne TT, 1997 993TT, 1912 Buick Model 34, Audi S8, 1976 912E, 2016 Cayenne Diesel
Old 07-04-2020, 06:29 AM
Correct. You have the leading edge on line with the notch. Make sure you’re #1 intake rocker is loose.
Bruce
Old 07-04-2020, 10:08 AM
Thank you Bruce and happy 4th! Appreciate it!
Old 07-04-2020, 02:24 PM
