Piston squirters install Australia
I have exhausted all avenues here by phoning around. In the hope some Australians use this forum for info. For my upcoming engine build I'm after a shop that can perform this work. Im presuming my 67s engine does not have squirters. I don't really want to send it to the US its costly and all I hear is horror stories about wait times let alone transit damage etc. I'm also after the by pass mod but this seems simple enough. I'm just not prepared to let a shop use my case for a first time run.
Thanks Lyndon
Old 11-07-2018, 12:34 PM
BURN-BROS's Avatar
Hi Lyndon, Have you asked auto haus Hamilton? They build a few engines, perhaps they have a source.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 11-07-2018, 01:34 PM
I will give them a call.
Lyndon
Old 11-07-2018, 02:11 PM
Ok good news. I at last have an answer. Spoke to Grant at Auto Haus. He has been down this path and he now sends all his cases to Ollies.
So I will make arrangements when the time comes.
Thanks Lyndon
Old 11-07-2018, 02:46 PM
gotta send it all the way to the usa anyway.. I'm looking at sending some cylinders over too..
One of use should book a flight and take the gear as luggage!
Old 11-08-2018, 01:15 PM
Surely someone in Australia can do this, I did it myself with the help of a machinist mate and his mill, it's not that complicated.
Have you given Kane at Zuffenhaus a call? I'm pretty sure he can help you out. He's in Preston.
andy
Old 11-08-2018, 04:14 PM
Geez, you guys are keen! Sending stuff to the US is a massive time and $$ commitment.
So glad that I was able to avoid shipping stuff off!
Old 11-08-2018, 05:08 PM
I have not needed any case work to be done by a machine shop yet, but I removed my squirters myself and got a look behind them, it is a relatively simple arrangement which I imagine any good quality machine should be able to execute.
Old 11-09-2018, 09:59 PM
Crankshaft rebuilders in Preston. I have rang and they are confident. Apparently they have done them before.
Thanks Lyndon
Old 11-11-2018, 08:09 PM
Give Richard den Brinker at PR Technology a call - I'd be amazed if he couldn't do this.
02 9905 6316
914/6 GT (Repro) Tarmac Rally car
928 S4 - 1989
911SC - 1980
944 TURBO - 1986
944 S2 - 1990
Old 11-12-2018, 03:57 AM
Try Bob Whymms Automotive (BWA P/L) in 45 Prince William Dr, Seven Hills NSW 2147 Tel 1300 292 288
He used to do machine work to early 911 Aluminium/Mag cases.
Old 11-13-2018, 01:56 PM
little squirt
hi lyndon,if your engine doesnt have pisto squirt holes i think thats a lot of work not only do the rods need to be drilled but i think cranckshaft has to be machined so so all oil holes line up and oil arrives at the thrust side of cylinder good luck .
Old 11-20-2018, 06:15 PM
