-   -   Can you ID this engine? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1014308-can-you-id-engine.html)
Nux 11-29-2018 01:03 PM
Supposed to be a 3.2, but I simply can't decode this engine number - any ideas?
Engine number 961057
http://forums.pelicanparts.com/uploa...1543525278.jpg
eastbay 11-29-2018 02:48 PM
Blurry picture, but isn't that 930/21 ? 84 Carrera
Flat6pac 11-29-2018 03:52 PM
The number is
More like a pre 68
Bruce
Trackrash 11-29-2018 04:39 PM
Those stars surrounding the engine number look suspect. Looks to be restamped.
ajwans 11-29-2018 05:21 PM
Serial number corresponds to 67S engine, type should be 901/02.
andy
Matt Monson 11-29-2018 07:10 PM
Look at the casting numbers on the case halves. 901 or 930 as first three will clear up a lot.
Nux 11-29-2018 07:56 PM
Indeed yes
http://forums.pelicanparts.com/uploa...1543550036.jpg
Why the odd engine number? Re-stamped?
I'll get some pics of the casting numbers. Think its a 930 case
Matt Monson 11-29-2018 08:01 PM
Appears restamped serial number.
djpateman 12-17-2018 05:11 AM
Definitely a faked serial #. As stated 961057 is a 1967 911S engine serial; however it is stamped in the wrong place. The early aluminum cases have the # stamped facing the rear not to the right, and also have a build # stamped under the type #. The stamped type # here is a clue to the original engine case, but what is within can only be determined by a teardown.
Ora 12-27-2018 02:16 PM
Re-stamped, no good., Sam.
Walt Fricke 12-27-2018 04:50 PM
Not necessarily no good. I've got a sand cast case race motor with non-matching case halves. Whoever did the machine work did a good job - everything lines up and measures up from what I can tell. Ran great until I rebuilt it, when some gremlin (unrelated to any geometry) struck.
No good for concours/purity/etc. But otherwise might be a fine engine/case.
Do what Matt suggested and let the forum know what the casting numbers are. My guess is it will be 930.
If it is 930, pull the clutch and see if it is a 6 or a 9 bolt crank. A 6 would be good, as those are rather rare.
