Can you ID this engine?
Supposed to be a 3.2, but I simply can't decode this engine number - any ideas?
Engine number 961057 ![]()
Blurry picture, but isn't that 930/21 ? 84 Carrera
The number is
More like a pre 68 Bruce |
Under the radar
Those stars surrounding the engine number look suspect. Looks to be restamped.
Serial number corresponds to 67S engine, type should be 901/02.
andy |
gearhead
Look at the casting numbers on the case halves. 901 or 930 as first three will clear up a lot.
gearhead
Appears restamped serial number.
Definitely a faked serial #. As stated 961057 is a 1967 911S engine serial; however it is stamped in the wrong place. The early aluminum cases have the # stamped facing the rear not to the right, and also have a build # stamped under the type #. The stamped type # here is a clue to the original engine case, but what is within can only be determined by a teardown.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
Banned
Re-stamped, no good., Sam.
Not necessarily no good. I've got a sand cast case race motor with non-matching case halves. Whoever did the machine work did a good job - everything lines up and measures up from what I can tell. Ran great until I rebuilt it, when some gremlin (unrelated to any geometry) struck.
No good for concours/purity/etc. But otherwise might be a fine engine/case. Do what Matt suggested and let the forum know what the casting numbers are. My guess is it will be 930. If it is 930, pull the clutch and see if it is a 6 or a 9 bolt crank. A 6 would be good, as those are rather rare. |
