Sealing case,covers etc
About to start my 3.0 rebuild. Most all of the aluminum will be bead blasted and wondering what the suggested coating/sealer is?
Tks gents.
ed
Old 12-19-2018, 12:51 PM
Ingenieur
You'll be wanting this thread:
The Complete Engine Sealant Thread...
Old 12-21-2018, 06:50 AM
al lkosmal's Avatar
I have been using the sealant kit from Supertec. Works very well! Available from Pelican.
https://www.pelicanparts.com/cgi-bin/ksearch/PEL_search_2016.cgi?command=DWsearch&description=sealant+kit
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 12-21-2018, 09:35 AM
Jeff Alton's Avatar
Are you looking for suggestions on what sealants to use while assembling, or what sort of coating (if any) you should use to protect the newly media blasted parts??
Cheers
www.turn3autosport.com
Old 12-21-2018, 07:12 PM
Under the radar
Trackrash's Avatar
So you are going to have ALL the motor parts bead blasted? Case, valve covers, cam housings, etc?
That is a matter of debate. Personally I would not bead blast my motor parts. Yea, the pros do it 'cuz it is fast and it gets things clean. Probably OK for heads. But a friend of mine, who runs a machine shop specializing in air cooled stuff with over 30 years of experience, showed me some heads that someone bead blasted. The seating surfaces were so rough that he was going to have to machine them in order for them to seat. Now, if the correct size of bead is used, the beads are not old and fractured, the correct pressure is used and the operator knows what he is doing, well you will probably be ok.
There are other ways to get the parts clean and polished. Then use Gibbs to protect.
Gordon
'71 911 Coupe 3,0L outlawed
Old 12-22-2018, 11:50 AM
Apologies guys. I guess that my question was not very clear
Wondering what to apply to the exterior aluminum surfaces post bead blast
FYI I followed Wayne s suggestions which parts were safe to bead
Looking forward to getting my 3.0 back together
Tks for your suggestions & Have a great Holiday
ed
Old 12-23-2018, 02:44 PM
proporsche's Avatar
outsider as trackrash said .....also have a look here ..that is using the proper engine case loctite 574.
I do it like this for many many years..my technique...
Ivan
https://www.youtube.com/watch?v=ZoOEFOkC2aA
this the only amount you need to apply to the case..
https://www.youtube.com/watch?v=IandhtwG5no
and cylinder heads
https://www.youtube.com/watch?v=STWf7WnC4xo
1985 911 with original 502 191 miles...808 198 km
Old 12-25-2018, 09:22 AM
abit off center
cgarr's Avatar
spray it down with some Gibbs
Craig
G2Performance
Old 12-25-2018, 11:25 AM
Craig
Do you spray the engine down after its assembled? or each part individually?
tks
ed
Old 12-25-2018, 12:23 PM
abit off center
cgarr's Avatar
I do some of the parts I rebuild like head sealing surfaces then sent to the customer, but if I was building an engine I would do it after assembled unless the parts are in storage for awhile.
Craig
G2Performance
Old 12-25-2018, 06:37 PM
Cobalt's Avatar
I would reconsider bead blasting the outside of any factory finished parts unless they are badly corroded. The as cast surface has an oxide layer that helps protect it from the elements. Once removed it will be far more susceptible to corrosion. This especially applies to mag.
If you need to blast you will need a good wash primer followed by a matt clear coat. Sikkens makes some nice products but you will need a pro to do them properly.
Here is a 3.2 intake a friend of mine just did.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 01-05-2019, 06:03 AM
Cobalt's Avatar
I should have suggested if you have access to a vapor degreaser that always works well. My case was a mess prior to degreasing.
My tranny was already heavily corroded and the oxide layer destroyed. After a bit of cleaning I hit it with Sikkens spray wash primer in a rattle can followed by Por 15 aluminum paint also in a rattle can. After a week I sprayed brake cleaner on it and it was not effected. I prefer the clean oxide finish but this is OK. I wasn't about to pull the entire tranny apart to bead blast and have my friend paint.
Old 01-05-2019, 06:27 AM
