Alright, let's get into it because KTL has some admission of error that he needs to fess up to...........
Here's how the error was discovered. Jon had asked me to take some pics of my various bearings with a measuring instrument on them, or installed in a rod. So before putting them in a rod, I took one and set it on a steel ruler. Ruler shows around 22/32" I plug that into my phone calculator and multiply by 25.4 mm per inch and get 17.46mm Wait......... 17? What????? THAT'S NOT 20MM!!!! http://forums.pelicanparts.com/uploa...1551370474.jpg So big apologies here to everyone for my measuring goof. All of my bearings are 0.69x" wide and therefore 17.5mm to 17.7mm. How did this happen? I misread my caliper because I see the 7 on the beam to the left and then simply add what I see on the dial. Well, the dial hasn't passed 0 yet. SO YOU'RE STILL IN THE 6 RANGE OF MEASUREMENT!!!! http://forums.pelicanparts.com/uploa...1551309820.jpg My error notwithstanding, it still doesn't explain why other people are experiencing bearings that don't align at their parting lines. So for additional comparison/beating this horse to death, I happen to have a 3.2 apart in my basement. I figured i'd take a look at those bearings since Dauner has problems with his 3.2 bearing alignment. I took a look at my 3.2 bearings and here's some pictures of the old bearings in the rod and measured (you read the measurement- I can't be trusted..... :p ) and also some pics of the "new" bearings I got from Porsche dealer network. I got the "new" bearings February 2018. I'm quoting the word new because the date on the box is February of 2008, not 2018! 1986 rod bearing with 77K miles. These are the original rod bearings from when the engine was first built by Porsche. They have 11-85 stamped on the back http://forums.pelicanparts.com/uploa...1551371988.jpg Width of 11-85 rod bearing http://forums.pelicanparts.com/uploa...1551372029.jpg "New" 3.2 bearing part number 93010314715 http://forums.pelicanparts.com/uploa...1551372202.jpg Width of that new bearing (you read the dial for yourself, please........ ) http://forums.pelicanparts.com/uploa...1551372225.jpg Porsche box for the 3.2 bearing shell with production date 2/8/2008 http://forums.pelicanparts.com/uploa...1551372265.jpg |
Your machinist friend is absolutely correct. The Rod big end bore size clamps the bearing in place. The bearings are not a perfect semi circle until they are fitted into the housing bores. The tangs are there for alignment in assembly. The only thing is to make sure when fitting the rods to the crank that the tangs are fitted in the direction of crank rotation. We are often narrowing the shell length and modifying the tang to fit the shells perfectly. There is no issue here. In fact, we modify the mains and the rod shells in these engines. Differently, but both are not fitted out of the box. Take a closer look at the shell and you will see that when the tang was broached into the shell, it not only went down but often went sideways some. This can push the shell into a very slight angle and the parting line of the other side will not line up as good as it should. It takes just a ting amount to remove the bit of the tang that protrudes sideways and the bearing will fit better. Do not modify the rod. |
I don't think there's been an example of a rod with good alignment with one set, and bad with another - witness KTL's rod which has better alignment with all his bearings, old and new, and mine which is bad, old and new, and other examples in this thread. You are correct, as is Neil, that no, the tangs aren't that important, it's the crush that keeps thing in place after assembly. |
I also made the incorrect assumption that since the alignment of the edges was off, it must be a bearing width issue, and not a tang/notch placement issue. I'll take .5mm or so off each tang and leave my rods alone. One small point, it's not possible to orient the tangs for rotation on these rods, as the tangs are both on the same side of the rod. 1 notch on the rod, 1 on the cap, facing the same parting line. |
Thanks a bunch, Kevin! You've spent a lot of time on this topic that really may have turned out to be much ado about nothing.
Oh well, if we lived in California we would be out driving, but what else is a snow belt dweller to do in the depth of winter. Quote:
"As a note, I did go ahead and install the original bearings, and they line up perfectly. Never mind the scratches. they have been all floating around in a ziplock bag." |
Anyway, I took a file to a pair of my used bearing shells - a few minutes work took a bit off the inside edge of the tang (.5mm) alignment much improved. So I'll go ahead and do that once I confirm I'm not messing up anything with the actual important clearances. I might build a fixture so I can do it in the mill, might be faster and more consistent that doing it with a jewelers file....:( Pic or it didn't happen: http://forums.pelicanparts.com/uploa...1551799523.jpg |
Hi everyone,
Original Poster here. Just to close out, I did end up returning the defective Glyco bearings to EBS and replaced with Clevite 77. As suspected, they line up perfectly, and my BE Bores were highly repeatable with a bore gauge after assembly and torquing down. Starting my assembly soon. thanks to all for the thoughts, comments, and suggestions. Regards, mark |
| All times are GMT -8. The time now is 02:02 PM. |
