Rod Bearing alignment of edges off
1989 911 3.2
Assembling Newly machined rods with new Glyco bearings to measure ID of big ends. What aligns / centers the bearing in the rod on the non-tang side? In pic below you can see that my bearings want to naturally sit not aligned. Prior to assembling halves together I can slide the bearing over a bit to center it, but it wants to move back. Has anyone seen this and is it normal? This is the first one that I have assembled, but want feedback before continuing on with rest of rods. Rod in picture has bolts torqued to about 20 foot pounds.
Mark
1989 911 Carrera 3.2
2009 Audi A4 2.0TQA
2017 BMW X3
2007 BMW 328xi
1971 BMW R60/5
Old 01-12-2019, 05:38 PM
Something's very wrong there. Rod should have one bearing tang per half, and each bearing should have a corresponding tang.
My guess is you have the wrong bearings.
Old 01-13-2019, 08:18 AM
Hi Catorce,
Yep, rods have 1 tang per half, and bearings have one tang each. When you assemble rods correcty with the rod numbers on the same side, you end up with tangs together, and no tangs together. This is the side with no tangs. Correct bearings and original rods to my car. Don't think that's the issue.
Thanks,
Mark
2009 Audi A4 2.0TQA
2017 BMW X3
2007 BMW 328xi
1971 BMW R60/5
Old 01-13-2019, 09:32 AM
Ok now I'm actually a little concerned. Are these the right bearings for a 1989 911 3.2?
Catorce you may be right on part number, but fitment looks right except the alignment issue
2009 Audi A4 2.0TQA
2017 BMW X3
2007 BMW 328xi
1971 BMW R60/5
Old 01-13-2019, 10:06 AM
Puny Bird
Mark Henry's Avatar
Lets see a similar pic of the rod without the bearings.
Might just be the pic but something looks funky with the rod cap partline.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 01-13-2019, 12:10 PM
VFR750's Avatar
Rod bearings should be similar in width to the rods. The picture looks like they are both significantly narrower and staggered.
That does not look right.
Old 01-13-2019, 12:30 PM
abit off center
cgarr's Avatar
Looks like maybe so much was taken off the cap that there is very little relief left in the cap for the tang to fit correctly
______________________
Craig
G2Performance
Old 01-13-2019, 12:39 PM
Rods were in very good shape before resizing. Assume they didn't lick much off prior to resizing.
New bearings mic out same as originals in all dims. Engine never been apart before now so width correct.
I'll email shop regarding part number.
Any other thoughts appreciated
Thx
Mark
2009 Audi A4 2.0TQA
2017 BMW X3
2007 BMW 328xi
1971 BMW R60/5
Old 01-13-2019, 01:16 PM
I should also point out that because I'm waiting for a rod bolt stretch gauge to arrive I did a plastigage experiment and gap looked about 0.05mm, so with in spec... that's why there are some markings on one of the new bearings...
2009 Audi A4 2.0TQA
2017 BMW X3
2007 BMW 328xi
1971 BMW R60/5
Old 01-13-2019, 01:24 PM
Mark Henry, forgot to attach pic of rod without bearings.
2009 Audi A4 2.0TQA
2017 BMW X3
2007 BMW 328xi
1971 BMW R60/5
Old 01-13-2019, 01:40 PM
smokintr6's Avatar
Send a message via AIM to smokintr6
Dauner,
Order a set of bearings from the Porsche dealer, or Porsche OEM bearings through our host and see if the fit is different. In the past three years or so there have been some pretty fantastic failures on glyco bearings made in third world countries. Yes Glyco makes the OEM bearings, but they have been proven to be not the same. When looking at the risk / reward I can't see a reason to not buy OEM bearings moving forward.
Old 01-14-2019, 09:01 AM
The finish on the bearing surfaces looks odd, normally you'll see more of a fine cross hatch pattern from the honing. Your new bearings appear to be the same width as your original example. I'd bolt the rod together without bearings, torque the bolts, and measure the big end for comparison to required dimension.
Old 01-14-2019, 04:31 PM
glyco was a well reputated source for all kind of bearing the older days. new glyco bearings are tricky. some can be used. others might not be used and others (south africa) should be thrown away without testing arround. worst quality you can imagine.
buy a set of other bearings and try again. that should solve the issue....
Old 01-15-2019, 01:23 AM
VFR750's Avatar
Are the stamped numbers on the same side of the rod? It does not look like it in the picture.
Old 01-15-2019, 02:56 AM
Daugaard's Avatar
rod bearing
Your have a late 3,2 motor maybe you need the bearings from a 3,6 they are smaller.
look at my pictures when i put in some aftermarked rods in my 3,2 i have to buy bearings from A 3,6.
Daugaard
Old 01-15-2019, 02:37 PM
Puny Bird
Mark Henry's Avatar
Tangs grooves are on the same side which would be correct.
Old 01-15-2019, 02:59 PM
And of course the cap and rod have the same number,,,,maybe too obvious,,,but have to ask.
Old 01-15-2019, 04:26 PM
I'm no expert by any means... but on my rods, the numbers on the rods are both on the same side. The top piece and bottom piece line up so the stamped numbers are both on the same side.
1987 Porsche 911 Carrera Coupe
Old 01-16-2019, 09:34 AM
smokintr6's Avatar
That's making the assumption that the shop resized the rods with the caps in the correct place. Probably a safe assumption, but if the machine shop happened to mix the caps, you would either need to start over with the rod machining (probably at a new shop), or keep the caps in the new alignment.
My guess is that the number is actually on the rod, but you can't see it because of the camera glare in that spot.
Old 01-16-2019, 10:30 AM
Puny Bird
Mark Henry's Avatar
I am somewhat...almost 30 years professionally and still learning, tang grooves same side, same as numbers same side.
Cap/rod numbers could be mixed up (I'm sure the OP has checked by now) but the orientation is OK. Not the issue.
My guess is incorrect bearings or mislabeled, doesn't happen often but I've seen this before.
Old 01-16-2019, 10:49 AM
