(man/dude)
Jonny042's Avatar
Fresh out of mutton tallow - what to use instead?
Installing valve guides soon but forgot to order specific lube for the job..... what can I use that I'll have on hand? WD40? Nev-r-seize? Grease? Butter? Olive oil?
Or should I wait for the right stuff?
I have done guides before but cannot honestly remember what I used for lube.
Thanks in advance! Jon
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 03-12-2019, 05:08 AM
Under the radar
Trackrash's Avatar
I fried some bacon just before I installed mine.
However, the Carrera manual specifies talc.
Gordon
'71 911 Coupe 3,0L outlawed
Old 03-12-2019, 02:05 PM
(man/dude)
Jonny042's Avatar
Hey Gord, I remember you said that but I thought you were joking!!
Sheesh, I don't have any talc either.
Old 03-12-2019, 04:04 PM
Under the radar
Trackrash's Avatar
My garage smelled like bacon for a while. Yea, Sun and others have a "special" lubricant. I researched it and the main ingredient was tallow in the professional stuff.
I couldn't see springing for the professional stuff and I like bacon.
Later I read in the Carrera repair manual they say use talc. I have never used talc, and it doesn't seem like a lube, but who knows.
I would think KY or similar would work, since it is organic and would dissipate in heat.
Gordon
Old 03-12-2019, 05:58 PM
How about heating the head up?
- Rob
Old 03-13-2019, 05:48 AM
(man/dude)
Jonny042's Avatar
- Rob
I'm going to do that too. Doesn't seem to be necessary (according to the manuals) but to me seems the kinder gentler way to go about it, and no downside other than a bit of time.
Old 03-14-2019, 09:26 AM
Straight shooter
Lapkritis's Avatar
Heat heads and freeze guides.
Sent from my SM-N960U using Tapatalk
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 03-14-2019, 10:24 AM
