JoeMag's Avatar
Throttle cable to TWM itb's
Anyone happen to have any pics of how you connected 993 throttle cable to twm throttle bodies and bracketry to hold throttle cable?
Old 10-18-2019, 10:01 AM
JoeMag's Avatar
Or any pics of throttle cable connections to TWM itb's. thx!
Old 10-20-2019, 04:35 PM
Jeff Alton's Avatar
On the Jenveys we use, we run a cable from the gearbox bell crank up to the throttle housing. But, the Jenvey's are set up for a cable and the 915/G50 in the G body cars have the bell crank. We use an off the shelf adjustable adapter to attach the cable to the bell crank and fabricate a simple bracket to anchor the cable sheath at the gearbox end.
We are just sorting out a similar issue with a 964 build that of course does not have the bell crank on the gearbox...
Cheers
www.turn3autosport.com
Old 10-20-2019, 10:42 PM
