-   -   1980 SC 3.0 Valve Spring Replacement Questions (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1019929-1980-sc-3-0-valve-spring-replacement-questions.html)
KM1966 02-02-2019 08:30 AM
My 80 SC has what appears to be a broken #1 Intake spring. After reading around a bit, it sounds like mine may be at risk for having compromised springs from the factory. So I'll just replace all of them. I have the springs/SIR Tools on the way. Getting ready for the push.
First question: should I just cut to the chase and drop the drivetrain? I've got stubby fingers and am not terribly confident in tight spaces. Will a partial drop work? (Had it out last year for a substantial refresh... everything else is still good, just need to address the springs this round)
Likely to have a bunch more questions so thanks in advance! SmileWavy
http://forums.pelicanparts.com/uploa...1549124868.JPG
mikedsilva 02-02-2019 02:35 PM
Can valve springs be replaced without taking the heads off?
Richey 02-02-2019 07:20 PM
valve spring replacement
I vote for removing the drive train . Do you want to make it a not so bad project or a manual dexterity test ?
Eagledriver 02-03-2019 11:32 AM
I had an intake spring break and just replaced the one. It wasn’t that hard to do in place. I would say the bottom springs would be easy by just removing the exhaust system. You’ll have to be the judge about doing the top ones in place.
-Andy
30westrob 02-03-2019 06:41 PM
Is their a reason for replacing all the springs. I had a 3.0 break a spring many years ago. I replaced only the broken spring. Put an additional 100K + miles with no issues.
Rob
KM1966 02-04-2019 07:52 AM
@mikedsilva Yes you can replace with heads on. Pelican offers tools from SirTools that enable this.
Manual dexterity is not necessarily my strong suit. Dropping small parts in places they should never go... more up my alley.
Planning to cut to the chase and replace all of them for two reasons:
1. I keep reading about a batch of springs that were compromised from the factory. Date range usually seems to include 1980. I assume the issue would have presented by now, but why take the chance (if accessible).
2. I had my mechanic check over all my work from last winter. He advised that most of the springs were "soft" and should be replaced.
Car has 93,000 miles. I assume original springs. Fairly inexpensive refresh.
Ok, car is up on stands. Going for the drop. Stay tuned.
boyt911sc 02-07-2019 01:05 AM
Valve spring removal........
I had done the valve springs removal by using P7E and P7I tools. If you are replacing all the valve springs, it would be prudent to do it with the motor on an engine stand.
Tony
mikedsilva 01-09-2020 03:47 AM
I'm aware of the quality issue for valve springs fitted to original 3.0 SC, but has anyone else had a failure of a fairly new spring?
I have a set ordered from our host 2 years ago; they've done approx 5000miles... found a broken outer on cylinder 6 intake today.
Not sure if I should replace all 12 sets, or just the 1 set? The ones I ordered were the generic OEM ones.. not Porsche genuine.
Open to guidance.
http://forums.pelicanparts.com/uploa...1578569350.JPG
