Rocker shaft removal bore scratches
When removing my rocker shafts I followed Wayne's book utilizing a 3/8 extension to tap them out. On my number one exhaust and intake shafts I noticed little bits of metal when they were fully removed. Every other shaft came out fine. When looking at the bore that the shaft sits in I see and feel some scratches. What's your thoughts on the bore being scratched (issue)? My thought is to polish it up to smooth it out.
Old 02-18-2019, 05:18 PM
SCadaddle's Avatar
My engine builder and myself used a small wire wheel brush from a Dremel kit attached to a long extension from a gun cleaning kit chocked up in a drill to lightly polish those bores, then added the RSR seals on all of the rocker shafts. Worked for me.
Old 02-18-2019, 05:28 PM
Dave,
Good to know. Thanks for the reply.
Old 02-18-2019, 05:56 PM
Registered Minimalist
75 911s's Avatar
They also sell the end caps now for the rocker shafts.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 02-18-2019, 08:01 PM
Puny Bird
Mark Henry's Avatar
Check to see that the holes are in spec, I'd say that was caused by the rocker shaft being loose and the shaft was pivoting on the housing instead of the rocker bushing.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 02-20-2019, 08:41 AM
Good point. Will do.
Old 02-20-2019, 06:31 PM
I did that too. I stupidly didn't remove the bolts and bushings when removing them and scratched a few like this.
I got a soft wire brush on a dill and cleaned it up. Also got some RSR seals and new shafts.
Engine isn't finished yet - so can't report if it has worked just yet.
Old 02-20-2019, 10:12 PM
KTL KTL is online now
Schleprock
KTL's Avatar
Duane,
Where do you find the caps that you mention?
Thanks,
Kev
Kevin L
'86 Carrera "Larry"
Old 02-21-2019, 10:02 AM
75 911s's Avatar
Kev
"Turbokraft Rocker shaft Lock Set"
Old 02-21-2019, 10:20 AM
Schleprock
KTL's Avatar
Ok thanks. I was aware of the Turbo Kraft shaft lock kit. I thought there was a just a cap someone makes to plug the end of the cam housing where the end of the shaft is recessed.
Kevin L
'86 Carrera "Larry"
Old 02-21-2019, 11:09 AM
