3.0 cylinder problem
Hi
We have a 77 turbo with a blown cylinder gasket.
The outer "ring" of the cylinder has some problem
What should we do with it? Our machine workshop confused
Old 12-02-2021, 10:40 PM
hmmm... to me, that looks like it's ready for the bin. Need to find a replacement cylinder.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 12-03-2021, 04:17 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Head stud failure. The cylinder pressure caused the head to lift and the gasket squeezed out. If the rings are in tact, it probably wasn't caused by detonation.
We have good used cylinders if you are looking for a replacement.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 12-03-2021, 06:16 AM
The previous mechanic forgot to connect the wastegate.
18 head stud was broken
Old 12-04-2021, 02:53 AM
Banned
thanks for the awesome information.
Old 12-05-2021, 04:32 AM
