-   -   Cam Tower Can Bearing Surface (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1023947-cam-tower-can-bearing-surface.html)
Germaneighter 03-18-2019 01:06 PM
1972 2.4T Build....or should I say pre-build...
1.) Is this normal surface wear on the cam bearing surface?
2.) What is the purpose of this small pin? (if it is a pin…)
http://forums.pelicanparts.com/uploa...1552939050.jpg
http://forums.pelicanparts.com/uploa...1552939395.jpg
Walt Fricke 03-18-2019 01:15 PM
It doesn't look bad to me, but others may have other views.
The "pin" is a plug for the drilling which takes the lubricating oil from the spray bar (assuming it is installed with the correct orientation) into the bearing below. If you stick a finger into the bearing area you can feel the hole.
