/ˈpɔrʃə/ PORSH-ə Fan
LUFTKUL's Avatar
SC Heads look good enough?
Can you tell me opinions on the state of these heads and valves? I dropped the engine in my '82 SC Targa to clean up some leaks and prepare the engine for a Bitz Kit EFI. I plan on using the CIS runners and modified stock central plenum.
I'm at the point I either leave the heads on and replace all the gaskets I can to fix the leaks or pull the heads off for valve guides, cleaning, etc. I ended up with 4 broken exhaust studs, but I have the Stomski kit and used it on another car with success so I think I will be OK doing that myself.
Car is supposed to have 88K miles, but TMU as I got no records when I got the car recently. I'm trying not to slide down the slippery slope of project scope creep, but I don't want to be foolish either.
Some of the shiny silver bits in the exhaust ports are from when I cut off the rusty heat exchangers before removing the nuts for easier access. I vacuumed inside before flipping the engine over, but some pieces still got in the there sticking to the carbon buildup. Since the pics, I got a really small attachment on my vac and got almost all the shiny bits I could.
1984 ROW Carrera Sunroof Coupe Schieferblau
1982 US SC Targa Moosgrun
1977 US 911S Sunroof Coupe - SOLD
Old 03-19-2019, 06:51 AM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Judging by the buildup on the exhaust valves , I say keep going and get the heads done. With the heads off, you will be able to at least see the bore condition and go from there. And if Dilivar cylinder studs are on the bottom, replace with steel. Once you start....
1986 Targa Guards Red
2021 MT09 SP
Old 03-19-2019, 08:52 AM
A valve job is one of the few places that make a valuable change for reasonable money, and 88k its time.
Bruce
Old 03-19-2019, 09:45 AM
safe's Avatar
That's cruddy exhaust valves! At least two of them seems to leak a substantiation amount of oil.
Magnus
Old 03-19-2019, 10:54 AM
LUFTKUL's Avatar
Thanks for letting me know. I don't have anything to compare them to as I'm unsure how much "normal" buildup there would be. I agree, two of them look like oil crud beyond just carbon buildup. The cam surfaces, rockers, etc. look great. No broken head studs either.
Old 03-19-2019, 11:54 AM
safe's Avatar
Check if the lower head studs are dilavar (non magnetic) or if someone has replaced them already. If you remove the heads and still have dilavar, change them out even if they ain't broken.
Magnus
Old 03-19-2019, 01:00 PM
abit off center
cgarr's Avatar
If you have the engine out to update with an ems I’d at least do a top end on it. The seats can get pretty oblong from shot guides over time
______________________
Craig
G2Performance
Old 03-19-2019, 07:37 PM
(man/dude)
Jonny042's Avatar
And in case you don't know, send a PM to Craig (cgarr, above) and arrange to have him do your heads.
His reputation for quality and value is second to none.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 03-20-2019, 07:21 AM
Craig does beautiful cylinder head rejuvenations. Straight-shooter to deal with. John
Old 03-20-2019, 02:28 PM
Puny Bird
Mark Henry's Avatar
Do them, the SC is a stout engine but known for for guide wear and head stud issues.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 03-21-2019, 05:00 PM
LUFTKUL's Avatar
If anyone has Craig's (cgarr) contact info can you please PM me? I PM'd cgarr but haven't heard back.
Old 03-28-2019, 08:20 AM
email: garrett@iserv.net
If you give your word: keep it.
Old 03-28-2019, 09:14 AM
