Max oil pressure aluminum crank plugs
Does anybody know what the maximum oil pressure is, that can be run with the factory crankshafts? I have a GT3 crankshaft I am going to install in a high boost/high rpm 930 engine and the crank has the factory aluminum plugs installed. On stock GT3's the max oil pressure is limited to about 5 bar, whereas on 935 and 962 race cars the max oil pressure was around 8 bar. Will the aluminum plugs hold at the race car pressure or will they blow out?
It's a 914 ...
I initially read your post and thought 8 bar was too high, but just referred to a copy of a 935 factory manual someone gave me years ago. Sure enough, it specifies 7.4-7.6 bar at 80 degrees Celsius oil temp. I wonder if anyone runs race motors at such high oil pressures these days.
If you go to YouTube and search for Spezial Motorer 935 dyno, you can see the oil pressure on the dyno screen is a steady 7.5 bar (reasonably recent, I guess). I also have a dyno sheet from an Andial/Schuppan 962 that shows 7.8-8.0 bar oil pressure. Question is, did those crankshafts have aluminum plugs or did the RSR/935/962 cranks have threaded or welded plugs?
Saved a lot of time and effort!!
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
What would it be considered too high oil pressure for a standard 3.3?
What size? I am guessing you use an NPT plug but would like to be educated. andy |
A friend with decent skills (paid for college by working as a machinist) once tapped his crank for this purpose. He said it was very difficult due to the toughness of the steel, and I think he broke a number of taps in the process (which is a problem all of its own).
I don't know if there are cobalt or other tougher taps the way there are drill bits. |
