Rosco_NZ
Send a message via Skype™ to Rosco_NZ
Bearing Cost
My engine builder has ordered 0.50 under BE’s & 0.50 over mains and delivered me an eye watering invoice saying they’re available Porsche only .. a quick search online shows otherwise .. eBay, Stoddards .. where else can I source these ??
Old 05-29-2019, 11:02 AM
Dealing with cut cranks and line bored cases, glutton for punishment.
Bruce
Old 05-29-2019, 02:14 PM
Walt Fricke's Avatar
Rosco
The machine shops which do a lot of work on Porsche air cooled cases have learned you don't just line bore the case, because that calls for oversized main bearings. And often their ID needs to be undersized, and that gets really costly.
Too late for you, I suppose, but the standard practice nowadays is to shave the cases a bit so that they can be align bored back to standard. First under mains aren't all that expensive, as I recall, if the crank is turned.
Old 05-30-2019, 03:26 PM
Rosco_NZ
I’ve got some more info .. the B/E journals and main journals are both 0.50 under, the cases will be line bored and machines back to standard .. my main beef if what he’s asking for these bearings as Stoddards has 0.50 mains for ~$350 and Pelican offers original Porsche B/E’s for $70 ... should be ~US$500 total ...
Old 05-30-2019, 06:10 PM
The 9 Store
Shops charge a markup on parts as well as labor.
All used parts sold as is.
Old 05-31-2019, 08:03 AM
You sure you can get oversized mains for $350? That does sound right. When I was looking, stock mains cost that...
Under or over sized I thought were $1000+++
Old 05-31-2019, 02:45 PM
