But yes, you are correct, some are well past their shelf life. These are generally from engines that have never been looked after. |
MORE POWER! :-)
I have a 964 hot rod, and a 997 GT3RS to feed that dragon. Having driven a few of these, it feels to me that low-mid 200HP range is just 'right' for the chassis. But that's me! |
Ok so I'm mentally getting closer here. I'll likely buy a core and build that, or if a good core swap it in car and build what I have...
Question: What are folks doing on oiling? I think the stock oil pump is a weak point? 3L or 3.2L pump? |
A 2200-2300lbs 911 is just right with 250-280ish bhp. Stock brakes are scary tho!
No physical quantity completely explains its own existence |
Under the radar
'71 was the last year of the smaller oil lines and oil tank. Newer motors had more oil capacity and flow. So you will need to address oil lines and the tank. Adapters are available but with a larger more powerful motor you may want to upgrade the tank, and most likely you will need a front cooler. With your 2,7 perhaps some of that has already been addressed? What intake, exhaust, ignition, and gauges will you need to match the new motor? If you are sticking with a 2,7 it will be easier than a 3,0 or newer.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 08-13-2019 at 08:54 AM.. |
Will do a 2.8
Have a carrera cooler already installed Intake will be some sort of itb efi plan there isnfull motec dual coil on plug crank fire ignition Exhaust is ssi currently with dansk sport muffler. Not sure if my oil tank has changed, likely not but, seems to be ok with current 2.7 and car runs cool |
On the oil tank. So the car has a carrera cooler with the thermostat installed. It runs a rock solid 170-180 in normal use. Hard driving in the mountains in hot (like 90+) i've seen it get up to 200 or so. If I were to get a later tanks, I assume, need a 73 tank? (72 is totally different right?). What other 'parts' would be needed for hoses, etc? I have a 77 911S 7R engine core I just got we are starting to disassemble. I'm going to build a different engine and then swap when done, and then refresh the one i have in the car now for another project. (won't 'build' it). First order is a huge machining bill from Ollies :-) I'd love to get 250 wheel, will be doing EFI, dual plugs coil on plug, 2.8L, and all the tricks. With EFI, suspect 10.5:1 is doable on 91 pump gas? For gauges, will keep it all stock, will update the Tach for a new redline, I suspect around 7500. Will use stock oil pressure/temp senders. For tach signal, not sure. |
Under the radar
Without knowing the details of your current setup, it is hard to answer.
What engine case are you running now and which thermostat for the front cooler? Maybe post some pictures of your oil tank and set up? I am assuming you have a 2,7 from a '74 or newer car? If so it seems that all the issues have been dealt with already by whoever did the upgrade.
I'm 99% sure oil tank is stock Case is a 7r from 77. New motor will be same, 7R case with all the tricks done once completed. Anyway, car runs cool with current motor, after cooler never seen it over 210 even with very hard driving in hot weather. The new build will be a more powerful motor. It will also be running EFI (Motec most likely) which should allow for better control and engine management. So the new motor will bolt in. I suspect if I wanted a later tank I'm looking at modifying some of the piping from the scavenge back to the tank? I DO plan to use a larger oil pump, probably a carrera pump. OK - I found some pictures at EarlyS http://www.early911sregistry.org/forums/showthread.php?44022-Pictures-of-the-different-oil-tanks-amp-senders Looks like: i need to modify the body sheet metal some due to swap of filter and filler. And, adapt existing hoses or go larger with new made hoses. Hm. Last edited by spyerx; 08-25-2019 at 09:01 AM.. |
Under the radar
It sounds like you have the adapters or special hoses for the '70 tank you have now. Yes, you would have to change the two fittings or oil lines that hook to the tank if you choose to upgrade to a newer tank.
Yea there is some minor sheet metal work that needs to be done in the engine compartment due to the different orientation of the filter. What type of hose do you have now that connects from the oil cooler on the motor to the oil tank? Do you have a hose that goes over the trans from the right side of the motor to the thermostat? Here is my tank. You can see the patch for the original filter location. ![]()
Thread Tools | |
Rate This Thread | |
