Halm's Avatar
2.2 E P&C's
I am probably going to do a full rebuild of my 2.2 E. Looking at our sponser's web site, P&C's for the 2.2 E are NLA. Where else should I look? I know JE makes pistons, what about cylinders? If so, are they a good alternative? Also, did I read that Mahle now offers replacement cylinders only?
'17 Cayenne
Old 03-23-2003, 06:51 AM
PRO Motorsports
Tyson Schmidt's Avatar
Since your 2.2 cylinders are biral, (aluminum fins with a cast iron liner) they can be bored to the next oversize. Then you can buy some J&E pistons of the proper size and whatever compression ratio you want.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 03-23-2003, 03:06 PM
Author of "101 Projects"
Wayne 962's Avatar
Indeed, if the original ones are NLA, then that is what I would recommend. I think that Mahle now has Nikasil 2.2s, but I'm not 100% sure...
If the 'S' pistons are available, you can have your cams reground to 'S'-spec and they should work okay. For the whole package, perhaps a recal of the pump and distributor?
-Wayne
Old 03-24-2003, 03:57 AM
Home of the Whopper
You could have the ring lands machined to accept thicker rings. But to do this your cylinders would have to be within spec. Most engines I have seen with the top ring land out of spec, the cylinders were also out of spec. Usually oval.
Old 03-24-2003, 09:25 AM
jluetjen's Avatar
If "S" pistons are available, just use them. They'll work great with E cams. That's what's in my 2.0E.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 03-25-2003, 12:07 PM
I can confirm that 2.2 E cylinders can be purchased in nikasil, that's what I got second hand from Brian Kolar last year ("BK 911"). Make sure you know what you have because the rings will need to be different, depending on whether you have Biral or Nikasil. If the cylinders are the former, you might be able to have them re-honed. If they are the latter, they are probably still good: nikasil is just about bullet proof.
Note to Brian: engine is running strong !
Michel Richard
Old 03-27-2003, 10:23 AM
Stressed Member
Scott Clarke's Avatar
If nikasil cylinders are used, consider modifying the case by having piston squirters installed, as nikasil clyinders were never intended for use without the squirters.
'70 911E short stroke 2.5 MFI. Sold
'56 Cliff May Prefab
Old 03-27-2003, 12:26 PM
Home of the Whopper
Sorry Wayne, I am going to have to disagree with you. If the only thing that is out of spec is the top ring land, then machining the top ring land is perfectly acceptable. Definitely in a street engine. The only thing it does is add some friction so you loose fractional HP. Rings are available in virtually any thickness. If you machine <.001" off the ring land and get rings to fit within ~.003" clearance, the pistons will last as long as new ones.
I believe the top ring on the 2.2's are 1.5mm. Some Porsche engines had 2mm top rings.
But as I said earlier, if your top ring land is out of spec, most likely your cyllinders are oval too. Everything has to be mic'd.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 03-31-2003, 07:10 AM
