It's a 914 ...
stownsen914's Avatar
#8 nosecone bearing sources - matters?
After cleaning up the nosecone bearing for my rebuild, I'm noticing a few nicks and scratches on the ID that I can catch a nail on. Although it measures within spec with a bore gauge, probably safer to replace. Do we need to be careful about the source of the #8 bearing like we do for other bearings, i.e. quality issues with Glyco bearings from certain sources?
Old 07-22-2023, 05:17 PM
It's a 914 ...
I see Rausch & Spiegel sells a #8 bearing. Is that a quality part?
Old 07-25-2023, 04:54 AM
I've used those and the cheaper OEM ones and never had an issue.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 07-25-2023, 06:20 AM
Probably the nicest part on my engine
Old 07-26-2023, 01:50 PM
