Targa_PB_78_SC
Valve timing 20/21 cams
So I am a newbie at valve timing. Are 20/21 cams more difficult to set the timing than a stock cam?
no, process is exactly the same.
john |
Targa_PB_78_SC
The process is the same, but the measurement value is different. Ensure you have the correct lift data at TDC overlap for those cams.
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
