Targa_PB_78_SC
mike sampsel's Avatar
Ring gap: JE set vs rebuild app A
JE pistons provided the following
Borex0.045” for min gap.
With 98 mm cylinder this yields
3.86”x 0.005 = 0.0193” or ~ 0.5 mm min gap
Seems to be wider than the values in Wayne’s rebuilding thesis (.2 mm - .4 mm) using 1982 - 1989 values.
I think I’ll go with JE numbers, just find it odd.
Curious what others do
Old 08-02-2019, 07:56 AM
ring gap
Be sure to look at the formula for what you are using the engine for, ie.street, race, blown/nitros etc. follow what Je suggest and you are fine, be sure they are square and detail the ends for burrs.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 08-02-2019, 08:40 AM
