(man/dude)
Quick and easy DIY P221 and P222
Just putting this here for people who might search for this in the future. I bent up my own out of some 1/8" welding rod. Took minutes, and cost pennies!
Project Heavy Metal - an all steel classic, remastered On my SC motor the #3 rod was happy enough to rest against the oil pump so no 222 required there. ![]() ![]() ![]() ![]() Since I didn't have a helper (or a third hand) I used a bit of wooden dowel as a lifting handle for the #1 and #2 rods.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Neat! Thanks for posting this!
Robert ----------------------------------------- "A man must consider what a rich realm he abdicates when he becomes a conformist." ~ Ralph Waldo Emerson ~ (thanks to Pat Keefe) |
I used bent coat hangers; not pretty but got me where I needed to be. Johnny 042's are nicer!
Filed under “Wished I’d thought of that”
![]() Sent from my iPhone using Tapatalk
'75 911S 3.2 '73 911 T MFI Coupe Silver Metallic (in progress...) Sometimes nothin' can be a real cool hand... |
I hope the picture is just a 'poser' shot of your crank in the case for us to see.
I don't see any assembly lube or a nose bearing installed.
1987 Porsche 911 Carrera Coupe |
Could you please post some measurements of p221 & p222
Clever bugger!
(man/dude)
Correct!!! Actually there is assembly paste on the bearing shells that you can't see.
(man/dude)
There are some dimensioned pics available if you search google images of the actual tools.
In my case they were custom fit. The P221 (long one) is as long as I could make it from a 36" piece of welding rod
