3.0 upgrade tach problem
just completed 2.7 to 3.0 swap. Everything is fine except that the tach doesn't work. Is this a wiring issue or do i need an sc tach?
Have you found an answer yet? I’m having the same problem..
Thanks |
I dunno - I had an SC tach in my '75 and swapped it straight for a '74 tach - it worked fine.
My '74 tach works fine with my SC engine. Try putting the old tach back in, and if it works, leave it.
Sounds like a wiring issue to me. Check the harness...
-Wayne |
Hey Novice...How did you hook up the engine bay wiring for your 77'...and how did the ECU hook up go.???? Thanks Frank with the exact same upgrade ...
| All times are GMT -8. The time now is 12:57 AM. |
