3.0 upgrade tach problem
just completed 2.7 to 3.0 swap. Everything is fine except that the tach doesn't work. Is this a wiring issue or do i need an sc tach?
Old 03-25-2003, 11:03 PM
Have you found an answer yet? I’m having the same problem..
Old 09-21-2003, 10:26 AM
CamB's Avatar
I dunno - I had an SC tach in my '75 and swapped it straight for a '74 tach - it worked fine.
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 09-21-2003, 12:37 PM
drag racing the short bus
dd74's Avatar
My '74 tach works fine with my SC engine. Try putting the old tach back in, and if it works, leave it.
The Terror of Tiny Town
Old 09-24-2003, 09:32 AM
Hey Novice...How did you hook up the engine bay wiring for your 77'...and how did the ECU hook up go.???? Thanks Frank with the exact same upgrade ...
Old 10-12-2003, 08:18 PM
