-   -   Euro spec conv. advice needed (http://forums.pelicanparts.com/911-engine-rebuilding-forum/103794-euro-spec-conv-advice-needed.html)
Nathan M 03-26-2003 05:27 AM
I'm in the UK and have a Swiss 3.2 with the US spec low compression motor. As I'll shortly be pulling it down to do the valve guides I've considered changing to the higher compression Euro spec pistons.
1. Do I need to change my cylinders for this? (i.e. Do the higher comp pistons have a different ring position relative to the piston pin & could this cause problems if fitted to a 70000 mile motor?)
2. what other changes to I need to make (if any?).
Thanks,
Nathan
Wayne 962 03-26-2003 02:13 PM
I think that the Euro pistons have a different shape on the top, which gives higher compression. I don't think there's anything involved, except the actual swap.
-Wayne
ChrisBennet 03-28-2003 10:22 PM
I had Euro pistons or Euro piston and cylinders in my US 3.2 from the previous owner. No problems.
-Chris
