Nathan M's Avatar
Euro spec conv. advice needed
I'm in the UK and have a Swiss 3.2 with the US spec low compression motor. As I'll shortly be pulling it down to do the valve guides I've considered changing to the higher compression Euro spec pistons.
1. Do I need to change my cylinders for this? (i.e. Do the higher comp pistons have a different ring position relative to the piston pin & could this cause problems if fitted to a 70000 mile motor?)
2. what other changes to I need to make (if any?).
Thanks,
Nathan
3.2 Coupe
Old 03-26-2003, 05:27 AM
Irrationally exuberant
ChrisBennet's Avatar
I had Euro pistons or Euro piston and cylinders in my US 3.2 from the previous owner. No problems.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-28-2003, 10:22 PM
