-   -   engine support on stand (http://forums.pelicanparts.com/911-engine-rebuilding-forum/103871-engine-support-stand.html)
ken martin 03-26-2003 02:07 PM
I have my turbo engine out and want to hang it on an engine stand,I've been told the 4 studs that mount the trans to the block will support the weight of the engine on an engine stand is this fact?? thank you
brandett 03-26-2003 11:52 PM
You are getting into a dangerous discussion :)
Opinions vary..
Check this thread
Wayne 962 03-27-2003 01:07 AM
As mentioned previously, I just heard the other day about an engine that broke on the 4-prong stands. Particular with a 911 Turbo engine (which is much heavier than a regular 911 engine), I would not go with anything but the official five-pronged stand.
-Wayne
ken martin 03-27-2003 07:58 AM
Wayne, did the yoke itself break or did the threads pull out of the block? I'm afraid that even using the 5 prong yoke the aluminum block threads would not hold the studs or bolts? The studs only screw in about an inch?
john walker's workshop 03-27-2003 08:17 AM
turbos definitely can be chancy in an engine stand. if nothing else, fab up a support bar between engine and floor. i had a mag case engine pull the top stud out once, which also broke the bottom stud off on the way down. just missed my foot.
WERK I 03-27-2003 06:45 PM
I currently have the turbo engine on the 5 yoke/engine stand. The engine had the CIS and heat exchangers when it was secured to the yoke. At that point, it is really no heavier than a 3.6 or 3.2 litre engine.
I say go for it.
Dave
85 factory slant turbo
