67 S distributor parts.
I'm having problems getting a set of advance springs for the 002 67 S distributor.
Any leads would be great.
Thanks Lyndon
Old 09-10-2019, 12:24 AM
did you try +Parts+Klassik+
Old 09-10-2019, 09:13 PM
Thanks I did. Its not a specific S spring. So I will go with what I have. I thought if the S spring was different it would be a good start for the bloke who is setting the curve
Thanks Lyndon
Old 09-11-2019, 12:24 AM
Under the radar
Trackrash's Avatar
You might try this https://www.jegs.com/c/Ignition-Electrical_Distributors/10381/10002/-1?N=1010381+4294946058&Tab=SKU
However, probably a little tweaking of the stops and weights will get your advance where you want it to be.
Gordon
'71 911 Coupe 3,0L outlawed
Old 09-11-2019, 07:46 AM
