Cbb Cbb is offline
3.2 Rebuild question top end, Bottom end?
I have a 1987 3.2 Carrera. using oil and fouling plugs. I am getting heads done, head studs replaced, Rocker Arms rebushed, and some camshaft repair / hardening for one area with mild pitting. Engine has 80+K miles. no leaks. I have no reason to believe there are currently issues with bottom end (Cylinders, Pistons, Rings look good). Would you do bottom end at same time? Rod Bearings, Polish Crank, New seals to prevent future leaks?
Thoughts?
thanks.
Old 10-17-2019, 12:29 PM
Chain fence eating turbo
I would not touch the bottom end!
New head studs (search this topic, heavily debated) and the heads rebuilt by Craig Garrett (cgarr) and carry on.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 10-17-2019, 12:35 PM
Jeff Alton's Avatar
Cylinders/pistons/rings are not part of the bottom end. When you say they look good, what does that mean? You can't visually inspect these components and declare them good. Was a leakdown and compression test completed before you took the motor apart?
Did the motor have good oil pressure before disassembly? Generally, the bottom ends are good for more miles than your motor has. But who knows how it has been treated over the life span. You are looking at 6ish hours to disassemble and reassemble bottom end plus machine time for crank inspection/polish and rod resizing. Plus small cost for new rod/main/IMS bearings, chains, gasket kit, rod bolts etc...
If you are keeping the car? Are you going to risk $$$$$ of work hoping the bottom end needs no work, or do you want to spend an extra $ to make it all new?
You may be OK with just doing the heads (which is not a compete top end IMO). But, once you are in there it makes good economic sense to make it ALL good at the same time.
Cheers
www.turn3autosport.com
Old 10-17-2019, 11:22 PM
sp_cs's Avatar
Agree
Extra ~15 hrs labour & cost of parts - bearings, inter shaft, pump maybe,...?
Should recoup your monies at resale time
Shirish
1987 Carrera, Granite Green
Old 10-18-2019, 07:40 AM
