Rocker Arm OEM?
I am rebuilding a 76 2.7 motor. 3 of the rocker arms have pitting. I have another set but they don't have the markers in the castings. In the attached picture the bottom/right set have marking cast in the arms and the ones at the top/left don't. Can I use the set without the markings? Were there multiple OEM providers of rocker arms?
George
74 911 Racer
08 Spec Cayman Racer
76 914 Cruiser
Old 12-01-2019, 08:49 AM
Yes, there are several different suppliers of rockers over the years..
Bruce
Old 12-01-2019, 04:00 PM
You may want to have them reconditioned as the bushings can have wear as well as the foot. Elgin Cams does a nice job. Bob
Old 12-01-2019, 04:03 PM
Try not, Do or Do not
Henry Schmidt's Avatar
We do a pretty nice job of reconditioning rocker as well.
Rocker process:
We remove the old bushing and adjuster (if present)
Clean adjuster threads with 8x1.0 forming tap.
Ream the bushing hole
Black Oxide the rocker
Press in the new DP-4 bushing and burnish
Surface the contact pad
Coat the contact pad with Moly dry film (TLML 2)
Treat the rocker to a Cryogenic conversion process
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 12-03-2019, 10:56 AM
Henry, those look good enough to eat. John
Old 12-04-2019, 04:07 PM
Thanks for the input.
George
74 911 Racer
76 914 Cruiser
Old 12-04-2019, 06:51 PM
