-   -   Crankcase Studs. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1043910-crankcase-studs.html)
coomo 10-30-2019 10:27 AM
Crankcase Studs.
Guys.I need to replace a crankcase stud.Car is 78sc.This is the lower pair that mate to box.Brought one home to measure, and it is 92mm.I used 1978 PET and 1986.Porsche did not make a 92mm (or even close!) stud,according to Parts diagram.
Am I missing something here?http://forums.pelicanparts.com/uploa...1572456330.jpg
r lane 10-30-2019 11:29 AM
Hardware store. If you need to be real specific, McMaster carr
coomo 10-30-2019 11:39 AM
yeah,I can get generic.I need precision.Thanks
Tippy 10-30-2019 01:46 PM
It's probably a 95mm stud. A lot of hardware is shorter than the specs. I assume this is so the hardware does not bottom out in a blind hole.
And there is nothing special about Porsche studs other than the headstuds AFAIK.
As stated above, McMaster-Carr or your local Fastenal should have them.
Flat6pac 10-30-2019 05:36 PM
The 3 short ones on the bell housing
999.061.034.02
Bruce
coomo 10-31-2019 10:06 AM
999.061.034.02
Bruce
Thanks Bruce.Its strange that these are 69mm.When the ones I removed were 92mm.Hope they are long enough.I presume they must be.
rikinada 10-31-2019 11:51 AM
cylinder/head studs
are the studs interference fit threads at the case?
What is the correct locking compound?
Walt Fricke 11-02-2019 11:23 PM
You don't need locking compound unless removing a stud damaged the case threads. In this application, best to install your favorite case saver insert. Typically these studs stay put when you go to remove the nuts.
30westrob 11-10-2019 06:21 AM
The PET stud length is only the exposed length of the stud, not the full length. Rob
boosted79 11-10-2019 06:26 AM
Correct. Very confusing until you figure that out. I use Belmetric for all my metric fasteners, they have anything you'll ever need and then some.
