Crankcase Studs.
Guys.I need to replace a crankcase stud.Car is 78sc.This is the lower pair that mate to box.Brought one home to measure, and it is 92mm.I used 1978 PET and 1986.Porsche did not make a 92mm (or even close!) stud,according to Parts diagram.
Am I missing something here?
Old 10-30-2019, 09:27 AM
Hardware store. If you need to be real specific, McMaster carr
Old 10-30-2019, 10:29 AM
yeah,I can get generic.I need precision.Thanks
Old 10-30-2019, 10:39 AM
Chain fence eating turbo
It's probably a 95mm stud. A lot of hardware is shorter than the specs. I assume this is so the hardware does not bottom out in a blind hole.
And there is nothing special about Porsche studs other than the headstuds AFAIK.
As stated above, McMaster-Carr or your local Fastenal should have them.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 10-30-2019, 12:46 PM
The 3 short ones on the bell housing
999.061.034.02
Bruce
Old 10-30-2019, 04:36 PM
999.061.034.02
Bruce
Thanks Bruce.Its strange that these are 69mm.When the ones I removed were 92mm.Hope they are long enough.I presume they must be.
Old 10-31-2019, 09:06 AM
cylinder/head studs
are the studs interference fit threads at the case?
What is the correct locking compound?
Old 10-31-2019, 10:51 AM
Walt Fricke's Avatar
You don't need locking compound unless removing a stud damaged the case threads. In this application, best to install your favorite case saver insert. Typically these studs stay put when you go to remove the nuts.
Old 11-02-2019, 10:23 PM
The PET stud length is only the exposed length of the stud, not the full length. Rob
Old 11-10-2019, 05:21 AM
Correct. Very confusing until you figure that out. I use Belmetric for all my metric fasteners, they have anything you'll ever need and then some.
Old 11-10-2019, 05:26 AM
